I was bitten by the TMPGEnc crash everytime I opened an AVI file as well. The problem is that TMPGEnc doesn't support the Pinnacle AVI format. I would suspect that most people with the strange TMP behavior are people with DV200 or DV500 Pinnacle capture cards.
So here's what you do:
Once you're done capturing in Premiere (which you should have since it comes with these DV200/500 cards), you need to run the AVI through a codec. I like the MPEG-4 codec because it makes the AVI files reasonably small, but there are some other choices. Once you've run it through and created a new AVI file, TMP will happily accept it without crashing.
Good luck.
Results 1 to 1 of 1
TMPGENC Xpress and Video Mastering Works both crash at 99% of .mkv to mpeg2
By i am x in forum Video ConversionReplies: 3Last Post: 15th Jul 2014, 08:40 -
Looking for an explanation of strange behaviour
By Duwgati in forum Authoring (DVD)Replies: 6Last Post: 29th Jul 2011, 07:03 -
Codec Explanation, which is best for this scenario ...
By andrewbutkus in forum Video ConversionReplies: 30Last Post: 1st Sep 2010, 10:15 -
Tmpgenc requires a serious solution
By 3doz in forum Video ConversionReplies: 8Last Post: 22nd Oct 2007, 20:31 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 00:38
