After copy the .mpg from SVCD to HD I try to add them into dvd author I get GOP is too Long on both files I have went into tmpgenc to fix them I loaded merge/cut VBR Program and saved the new .mpg and tried to open in dvd athor but same error. any other quick solution? If I converted them both to one file to a DVD ntsc .mpg will it work with no gop errors?
cool that it works all the time I heard that also if you just ignore it yeah it will play but only on dvd players that support SVCD. So i should just use SVCD2DVDMPG and load that into TDA and if it says GOP too long just ignore it and it should work fine on my standalon dvdplayer that only play dvdRs?
I haven't specifically used svcd2dvd, but I have had a lot of different video from different sources that had "fatal" GOP errors in TDA and every single time I was able to correct using TMPGEnc>MPEG Tools>Merge & Cut>Type = MPG Program (VBR)> Save As....
As far as choosing ignore as an option...test it yourself using a RW disk, then you'll know if it works for your standalone player
help with megui error plz
By runLoganrun in forum Blu-ray RippingReplies: 1Last Post: 17th Feb 2010, 21:43 -
VCD to DVD (TDA error: GOP too long)
By jelir in forum Authoring (DVD)Replies: 1Last Post: 6th Jun 2007, 09:40 -
VirtalDub ERROR - plz help
By UmmAddan in forum DVD RippingReplies: 3Last Post: 30th May 2007, 17:52 -
SCR <> GOP error in Gui for DVD Author
By rain in forum Authoring (DVD)Replies: 6Last Post: 22nd May 2007, 11:51 -
Glossery - Error in Closed GOP definition
By SCDVD in forum FeedbackReplies: 0Last Post: 8th May 2007, 18:08
