i'm trying to convert an avi file at 23.97 to DVD NTSC. It appears that the conversion will take almost 24 hours. Is this a normal conversion time for this. I've converted many things with TMPEG but it never has taken anywhere near this long. If this is correct, can someone tell me what the program is doing that it takes that long (just from a curiosity standpoint).
Thanks,
Jeff
Without your PC specs, input file specs, and complete description of what you asked the program to do, estimating the timing issue is impossible.
I have a banana in my kitchen. How cold is it?
Don't change framerate with TMPGenc. Use Pulldown.exe. -
What color is your bananna ? We need to know this
to answer the question. -
Is your banana ripe!?!?!? 8) :P :P
"We know who we are, but not what we may be" - William Shakespeare -
TMPGenc is a very slow encoder, generally you just have to live with the long encodes or go with a higher end program. But, in this case there is probably a decent explanation. The only way to properly convert 23.976fps to 29.97fps is to run a telecine. This is a very complex procedure (CPU wise) which requires that each frame be split into fields and that the fields be repeated in a 2:3 pattern. This would definitely take longer than a typical encode.
Now with that said, you are doing this all wrong. Unless you need analogue output, there is basically no reason to ever do this type of conversion. As you have noticed, it takes a long time and actually it is significantly lower quality. The DVD standard supports the 23.976fps framerate internally. This means that you can encode at 23.976fps, and then just enable the RFF/TFF flag and the player will telecine it to 29.97fps in real time as it plays. This gives you a huge increase in quality and makes the encoding process faster and easier to boot.
In TMPGEnc, simply set the output fps to 23.976fps, and set the encode mode on the video tab to 3:2 pulldown when playback. If you are using the DVD template than just load the unlock template first to change these settings. All 23.976fps sources should always be kept that way for NTSC output.
As Nelson37 said, you can also use pulldown.exe to enable the pulldown flags as well. So you'd just encode to 23.976fps using any mpeg encoder first, then run it through pulldown.exe. -
I assume I continue to use the DVD NTSC setting for No. America so I've changed the settings and started the conversion. However, the time left from TMPEGnc is showing some ungodly time left. SOmething like triple the time it was when I originally asked the question.
as far as the rff/tff flag, that's on the actual dvd player, correct?
i just checked and the time left is showing 90 hrs. Thios can;t be correct.
Thanks,
Convert AVI to ? to TMPGEnc DVDAuthor with 5.1 audio
By NDMMackay in forum Video ConversionReplies: 2Last Post: 15th Oct 2011, 07:02 -
Why do I have multiple files when I convert HD to SD using Tmpgenc??
By Endoking01 in forum Newbie / General discussionsReplies: 12Last Post: 9th Jun 2010, 21:43 -
Convert mp2 file in TMPGenc
By sdlehman in forum Video ConversionReplies: 1Last Post: 17th Mar 2008, 16:53 -
How to convert Mpeg2 to DivX using TMPGEnc and SimpleDivX
By rwmol in forum User guidesReplies: 14Last Post: 29th Jul 2007, 23:57 -
Convert to Zune compitable Qucktime using tmpgenc 4
By frogman54 in forum Video ConversionReplies: 1Last Post: 14th Jun 2007, 14:21
