TMPGENC plus 2.5 - worked perfectly several times but NOW: it takes forever and i mean like up to 10 minutes to load up - once it's loaded i'm able to navigate through the wizard just fine etc - i encoded, then authored with TMPGENC Author - burned and i got nothing!?!?!? the dvd shows a recorded area of only about two inches - it doesnt play in any dvd player either.......this unusable end result has happened three times on three different movies.
all other program on this pc seem to work fine - i uninstalled then reinstalled TMPGENC several times - even used a reg cleaner in between the uninstall and fresh install - still same problem. one clue - when i reinstalled the program had "remembered" that i changed the temp file folder and working file folder how can that be if i removed it entirely and started over?
i'm befuddled!?!???? any ideas??? thanks in advance!
I had a similar problem. I was afraid to delete the folder in the registry
so I created a new Windows userid and logged on with it. Since then I've
had no problems. The vendor was no help at all.
CUDA not working with TMPGEnc VMW 5
By indymudcat in forum Video ConversionReplies: 3Last Post: 29th Mar 2012, 14:33 -
Why wont TMPGENC start?
By TheLaserdisc in forum Authoring (DVD)Replies: 0Last Post: 12th Aug 2010, 18:16 -
Got ripbot working, BUT it wont stream to my PS3
By Fiostech in forum Blu-ray RippingReplies: 5Last Post: 5th Feb 2009, 13:15 -
TMPGENC wont accept an mpeg :S
By chocolate_brownie in forum EditingReplies: 4Last Post: 7th Aug 2007, 18:34 -
TMPGenc 2.5 not working in vista?
By yogart in forum Video ConversionReplies: 5Last Post: 7th May 2007, 02:37
