Hi,
Not sure if this is a problem with the encoding, burning, or my DVD player, but I can successfully burn a VCD and play it back on my standalone DVD player, but the audio is missing...I've tried all related suggestions/fixes I've found online but nothing has worked, not sure what to try next. Here's my scenario:
- short single video clip, plays fine on PC (converted originally using Media Cleaner Pro to VCD MPEG specs, reconverted using TMPGEnc)
- burned using VideoCD 2.0 option in CeQuadrat WinOnCD onto CD-RW (originally used CD-R's, but the DVD player wouldn't recognize them)
- trying to play using Sony DVP-S360 DVD player
I've tried:
- verifying that the file is within specs, and re-converting using TMPGEnc's "VideoCD (NTSC)" filter
- using VirtualDub to save the audio as a separate WAV and referencing the WAV as the audio source in TMPGEnc
- burning a new VCD with the sample file from vcdhelp.com (VCDNTSCSample.mpg)
Based on what I'm reading, TMPGEnc/VirtualDub/WinOnCD should have no problems, and it wouldn't seem to be related to the encoding/conversion, as the VCD of the sample file plays the same way (video's fine, no audio) - I've read that other people can play using my model DVD player, so I'm stuck...any suggestions?
Thanks...Colin.
I also have winoncd, it works great. I would think it might be the cd player that is in fault.
try an apex dvd player they are cheap and recognize all types of formats.
IF YOU HAVE ANY QUESTIONS, EMAIL TO
roncool1@pacbell.net
good luck ron b.
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 14:11 -
Media Player Classic no longer playing audio for some reason...
By darkzero297 in forum Software PlayingReplies: 5Last Post: 21st Feb 2009, 15:56 -
Is their software for playing MP3/Audio files on a 4.3GB DVD in a CD player
By jbitakis in forum AudioReplies: 8Last Post: 26th Jan 2009, 01:04 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
VCD problems (playing using VLC; no menus in Media Player)
By pwhyles in forum Newbie / General discussionsReplies: 15Last Post: 17th Jan 2008, 14:16
