Results 1 to 11 of 11
  1. Does anyone know what this error means
    Jul 2003
    LA - Lower Alabama
    From my past experience, it means there's a fingerprint smudge on the DVD you're ripping. Take it out of the drive and use a soft cloth to wipe the DVD from center to outer edge.
    99% of the time for me, that's solved the problem.
    Now a question for you - What's the name of your theme and where did you get it? Looks really sharp.
    Jul 2003
    LA - Lower Alabama
    Looking a little bit more closely to your original post, it looks like you are using DVDDecrypter to burn an ISO image. Sorry, my first response was geared towards ripping the image to your hard drive.
    You could check to see if there might be any type of scratch or smudge on your blank DVD that you're writing to.
  4. Originally Posted by Fairhope
    The theme is called sotart for windowblinds, i also use chrome cursor for cursor xp which can all be downloaded from www.wincustomize.com
    Thanks for the reply i'll see if it's just a bad disc although i have a funny feeling it's gonna be more than that
  5. what brand media are you using?
    most likely it is bad media.
    i got an error like that once too, it was fixed after buying better quality media.
    hope this helps.
  6. wait, are you trying to rip a ram disc? if thats so you cannot rip a ram with decrypter. For ram, you have to go into the main folder on the actual disc, and copy the .vro file over to your pc and once done rename it to a .mpg
    Nevermind i read that post wrong.
    Dec 2002
    My Swamp
    Just a word to the wise
    Be careful showing your film titles in your posts , as far as I can tell that film isn;t released till mid April. And this forum has a zero tolerance level on Warez . Just be a bit more careful in future.
  8. actually i thought the film was already released overseas on dvd now?
    Dec 2002
    My Swamp
    I had a quick look here.
    But look at the file size 4.5 GB It's best to be careful.
  10. i would agree a "pirate" it be arrgghh
    Feb 2004
    we here, we READY!!!
    I've seen a very simular error when trying to burn an image of a previously made DVDr. cleaning disk didnt work. i also get this unrecoverable read error message.
