Results 1 to 27 of 27
Both are free, you can try each and decide for yourself.
I have used dvdback and have never had a problem with it. Each does the same job (although you can rip out just the movie with mac the ripper)
You can burn dvd's with toast 5.
Hope this helps -
MacTheRipper removes RCE protection as well, and doesn't require you to play the DVD with DVD Player first. Also, it rips DVDs from different regions than the drive is in. It's also undergoing active development, whereas DVDBackup is good as dead (unless the author can find a way to charge for it, which is unlikely since he's a USian).
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
I am glad to have mactheripper to help rip dvd.
With myG4cube, i still have to double check the folder size after mactheripper finished the job because many times the ripping is complete.The job would stop and appeared it is over, but indeed, many times,it stopped because i have mutlitasking going on, it hiccups and quits without saying so .Bottomline, instead of saving time, it takes more times to do the job again, Now i don't do more than one job at a time, but may be just because my cube is only 450 hz. -
Hmm, that is quite an annoyance, especially for those who might not think to make sure the folder is the right size. I'll pass the suggestion on to Geezerbuttz, and hopefully he will be able to find a way to notify the user whether the process completed successfully, or if there was an error. You can also hit the "i" button at the end of the process and check for any errors printed on the last line there.
Thanks for the tips about using i button.
It is not a matter of annoyance to me, may be perhaps i am compulsive.
But it is true that mactheripper is less stable if there is multi-tasking.
I am using mactheripper as the dvd ripper as choice exactly you said, dvdback up has stopped its development.And mactheripper is more slick, not having to play the dvd by apple dvd player first.And i don't have to create a folder for the VIDEO_TS folder to go in.I am sure the next version of mactheripper is going to get more stable etc. -
Exactly how is it unstable? Does it actually ever crash? If so, we'll need to get some data from you to get the issue fixed. Please describe the symptoms of the instability, along with what kinds of multitasking might interfere with it. I always multitask while ripping, though I have a dual processor Mac, so maybe it affects me differently.
My vote goes to MacTheRipper...Works very well and it keeps getting better with every update...Authors listens the comments and working on improvements very fast...
Mactheripper has never crashed. But it stopped ripping the dvd and at a glance one may thought the process is complete until checking the designated folder.It happened a lot if i have several programes running at the same time.Like using toast to burn a dvd, browing the internet, itunes activity or dvd player to play a movie(i have an external dvd burner, so if i am not burning a dvd, that can be used to check out another dvd etc).
For the badly fomatted dvd disc, the same situation happended. For the same situation, DVD BACKUP would have an error message. -
Well, we'd like to know what kind of errors you find in the info drawer (when you click the "i" button), but I doubt it's in any way related to multitasking, as OS X is very good at resource management and memory protection. We can be reached at mtr@wormintheapple.gr for support.
Originally Posted by strpyw
Re: MTR -- is the process finished or not?
FWIW: I agree that if it is not too much trouble, having some sort of "I'm done" notification would be nice. -
Thanks for the input everybody. I'm a total noob to DVDs.
I gave MTR a try with the animated feature, Spirited Away. It took about 45 minutes to rip using the movie-only option on a G4/933. Awesome app! Kudos to Geezerbuttz and/or Wise Weasel.
So, my next question would be: in DVD2one, do I want to do a DISC COPY or MOVIE COPY in order to have a working DVD menu and scene selection? Or is the menu/scene selection not possible?
(I realize I could probably figure it out by trial-and-error, but unfortunately, I don't have access to this Mac often so I'm trying to save time.) -
Originally Posted by DirewolfIf it isn't broken, take it apart and find out why.
blog: deadsierra -
Hmmm, but I only ripped the movie using the Movie-Only option in MTR, and the output folder is something like 4.9GB (vs. 7.71 for the whole DVD)?
Sooooo, do I want to do a DISC COPY or MOVIE COPY in order to have a working DVD menu and scene selection? Or is the menu/scene selection not possible?
Sorry if I'm mistaken in any way -
blog: deadsierra -
blog: deadsierra -
Since I only have access to a superdrive Mac a few hours per week, I was hoping to not have to experiment too much.
Maybe Wiseweasel can clarify the "Main Feature" rip option? -
blog: deadsierra -
Main Feature mode in MTR will only back up the movie only, and none of the menus or extra features. If you wanted menus, you should have done a Complete Disc extraction, and then done full disc mode in DVD2OneX. If you did Main Feature mode w/ MTR, no matter what you choose with DVD2OneX, you'll get only the main feature, without any menus or extra features.
Ahhhhhhh.
Thanks wiseweasel and deadsierra.
I guess I was trying to modify Galactica's method for a movie-only backup (http://webpages.charter.net/ernsta/highquality.htm) but instead of using DVDbackup in step 1-2 of his procedure, I was trying MTR's main-feature option instead.
So if I do a Complete Disc Extraction in MTR, and then continue with Galactica's instructions, this should work?
Sorry to take up so much of your time. I appreciate your prompt responses. The Mac "community" continues to impress me even after 18 years of being a Mac-head. Long live this forum. -
Originally Posted by WiseWeaselIf it isn't broken, take it apart and find out why.
blog: deadsierra -
just using a differnet ripper is all
ill update my site soon to use the new apps on the scene, just no time now.... -
Well, it's done.
I chose Main Feature in MTR.
Then Disc Copy in DVD2one.
And finally Toast 5 for the burn.
I now have a working copy of Spirited Away with the following results:
The movie loads up immediately with no FBI warning and no dvd menu. And now that I think about it, I like this way better for my kid since he won't have to press anything to start watching the movie. Obviously, there's no scene selection since there's no dvd menu, but he doesn't need that. Chapter forwarding/reversing works. Fast/slow forward/reverse works too. Same with the English subtitle I chose in DVD2one. Now I don't have to worry about him scratching up the real dvd.
Overall, I'm very happy with the outcome and quality of the DVDr. There was some pixelation for the first 2 seconds of the movie, but that's about it.
Next, I'll give Galactica's advanced DVD to DVDr method a try using MTR and DVD2one. Great tutorial, Galactica.
Mactheripper ... fantastic program. Keep up the good work.
Thanks for the responses, everybody.
Bye -
If you wanted menus, you should have done Complete Disc mode in MTR, and then done Galactica's tutorial.
MacTheRipper - couple of probs
By satcure in forum MacReplies: 3Last Post: 24th Aug 2010, 14:44 -
MactheRipper - Solutions and alternatives?
By JonnyPhoenyx in forum MacReplies: 1Last Post: 4th Mar 2009, 12:41 -
MacTheRipper/Popcorn
By monieeka in forum MacReplies: 3Last Post: 21st Jul 2008, 02:39 -
Single vob file in MacTheRipper?
By bmoney017 in forum MacReplies: 2Last Post: 20th Oct 2007, 02:07 -
i'm really new, i have no idea what happened with mactheripper: dvd to fcp
By relativist in forum MacReplies: 6Last Post: 5th Oct 2007, 19:41
