  1. I know this topic has probably been brought up a thousand times, but is there a way to make vcd menus. I am compiling music videos in VCD format and would like to have a menu to choose which video to view. Thanks
  2. The answer to your question is "yes" and it has been brought up a thousand times before...
    1. Read the guides on the menu to the left
    2. Search the forums, there's plenty of info on a whole number of methods.
    Since I'm involved with the development of VCDImager, I naturally have a bias for it. I recently wrote a number of guides about authoring with VCDImager. Two of them involved menus: http://www.geocities.com/medinotes/vcd/
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. Yes use tscv 0741 you can get the freeware program from doom9.org in the downloads. If you use Nero5.5 it also makes menus(if enabled) when burning the Vcd. Roxio Easy cd creator platinum will also make menus. Another program Iauthor will make menus this program is no longer available to download.
  4. You shoulda skimmed the other forum topics first (not to mention all those great tutorials on this site).
    I'm using DVD MOVIE STUDIO and am pleased with the ease of use and the options it offers. The full product is only $44, and there is a FREE fully functional 30-day trial version available.
    Download it at: http://www.ulead.com.
  5. http://www.personal.psu.edu/users/r/d/rdm186/
    link..tells you everything you need to do either full motion menus, still menus, chapters...whatever
    check it out
    lemme know
