Just got dvd2one and I'm trying to put a 7G movie on a 4.7 DVDR. In disk copy mode, I got a VIDEO_TS that totalled 4.4G, but when I went to burn it in Toast, I got an error saying there were too many vectors. I tried to process again with target size set at 4400, but I got the same error. The resulting VIDEO_TS file plays fine in my Apple DVD Player, it just doesn't wanna burn. Right now, I'm trying to process again with the target size set at 4300, but I wanted to seek some advice while I wait.
Any tips? Could it be the media I am using? They're not the best DVDRs on the market, to be sure. This is my first attempt with dvd2one, so please be gentle.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
lowest I ever had to go was 4300 and that was run of the mill cheap o schmeapo free meida i got to test.
How many sectors off are you? it should tell you and you can hopefully then figure out how much you need to decrease it by -
Thanks for the tips. I reduced to 4200 and was able to burn, no problem.
What DVD media do you recommend to prevent this problem in the future? -
I use Apple and TDK, although Apple 2x media is very hard for me to find these days.
I've had very good luck with Ritek media. It's compatible with everything I've tried (unlike most others), and is very competitively priced.
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 02:48 -
How to burn DAO data disk
By logannsan in forum ComputerReplies: 4Last Post: 22nd Jun 2009, 12:17 -
How to burn music folders in a dvd disk?
By sumeshkri in forum AudioReplies: 20Last Post: 10th Mar 2008, 23:10 -
Burn in Disk Utility
By andredanton in forum MacReplies: 4Last Post: 12th Feb 2008, 12:41 -
Burn AVI file to DVD disk
By clms in forum Newbie / General discussionsReplies: 10Last Post: 20th Jul 2007, 14:10
