Heres a screenshot of the error I got in DVD Shrink....I've tried using DVD2ONE, and AnyDVD /w Clone DVD and I keep getting a similar error.
Any Suggestions?
WELL HERES THE ERROR ... FOR SOME REASON MY SCREENSHOT WON'T UPLOAD ...
"COPY PROTECTION ERROR. THE READ FAILED BECAUSE THE SECTOR IS ENCRYPTED"
Results 1 to 10 of 10
Anthony
Can you tell us what DVD yu are trying to backup and the version of SHrink. Are you using DeCrypter first of just Shrink. Just a little more about the process steps.
How is that message coming from Nero when I haven't even began to try and burn it since DVD Shrink won't even analyze the disc.
I tried using DVD Shrink 3.0 and I get the same message .. As for DVD Decryptor it just sits there and does the same thing in its own little way.Anthony -
Try the following:
Make sure your source disk is clean - I use alcohol to remove fingerprints, dirt, etc.
Use Windows Media player or whatever software you use to play DVDs on your computer. When the movie starts playing, pause it.
Open DVD shrink and then the drive letter that represents the source DVD.
I'm not 100% sure this will help, but I have read threads where some disks will give you this protect error unless you have previously accessed it with a software player. And this has always worked for me whenever I have had this problem. -
I am using Shrink 3.1.7.5 and have ripped, shrunk, and burner Identity without any problems. I used Decrypter (3.2.1.0) first and then Shrink, and burned with Nero 5.5.10,19. If you are using these programs, the problem has to be somewhere else.
I cleaned the disc and tried it in a different drive and it seems to be working ok now.
Anthony -
Originally Posted by Shudder
BoBo Bolinski
Dvd Shrink Gives me and error?
By mrjust in forum Newbie / General discussionsReplies: 4Last Post: 12th Jun 2010, 19:05 -
DVD Shrink 3.2 .IFO Error
By michpearl in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2010, 23:02 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 15:59 -
dvd shrink reauthor error
By victoriabears in forum Newbie / General discussionsReplies: 1Last Post: 16th Jan 2010, 15:09 -
Error when trying to shrink DVD files
By bambam in forum DVD RippingReplies: 10Last Post: 9th Jul 2007, 11:54
