its free btw -- new version out now with a lot of added features:
http://www.debugmode.com/wax/Wax is a high performance and flexible video compositing and special effects software. The idea for Wax is to be very general purpose and flexible in video compositing and effects, so that you can compose your dream video sequence with ease everytime.
Wax can create 2D & 3D special effects and can work in two modes - as a standalone application which would appeal for home users/beginners, and as a "plug-in" to video editors/NLEs which would be more useful for professional editors. Currently Wax can as a plug-in with Sony Vegas® and work for integrating with various other NLEs is in progress.
Features
Distributed as freeware for business or personal use. However if you want to redistribute, you need to inform the author.
Use graphics acceleration available with your video card for creating mind-boggling effects in realtime or near-realtime.
Unlimited video and audio tracks with top-down compositing (audio support is minimalistic at this time).
2D and 3D Plugins and transitions for creating effects. Full featured 3D compositing with 3d objects, lighting, shadows, texture generators, etc. Plugins include the following.
RotoMate - rotoscope/paint over video with fully keyframmable shapes and masks
Shatter - create explosive effects
ModelLoader - load 3d models from .3DS, .MD2 and .MS3d files
Particle Generator - generate various natural particle effects like fire, smoke, rain etc
Text 3D - create extruded/beveled 3D text, and much more...
Has native support for Plugin Adapter technology - can load and use VirtualDub filters, DirectX plugins and Windows ® Movie Maker presets inside Wax or your NLE when using Wax as a plugin.
Full featured project management with media bins/folders, element properties and comments for ease of use.
Transition and Plugin SDK available for developers to extend functionality by adding external plugins. WinMorph uses this Plugin SDK to extend Wax's functionality for warping and morphing.
File input/output through filters, Filter SDK available upon request for developers to extend file format support.
Input formats : AVI, WAV, all popular image formats.
Output formats : AVI, MPEG, WAV, Flash, all popular image formats.
(AVI and WAV formats support compressed audio too, using Audio Codecs installed in your PC).
Awesome!!!...just got it. Finally, a particle generator for Vegas...BTW, what does this mean:
Note for Vegas users
With Vegas 4 and above the plugin needs to use scripting so please download and install the .NET framework if you havent yet. -
ok...I picked up and installed the .NET compact framework...but that sure didn't make the plug-ins work in VV4
it works fine -- using it right now ..
if you have a problem , you can ask him about it on his support forum ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Originally Posted by Red96TA
Vegas Pro 9.0 (64bit) won't see installed Filter/Plug-In
By mltwitz in forum EditingReplies: 1Last Post: 26th Aug 2010, 13:16 -
Mercalli Stabilizer Plug-in for Sony Vegas Pro 8
By SCDVD in forum EditingReplies: 3Last Post: 16th Dec 2008, 23:39 -
Skin effect plug-in Vegas Pro?
By jnaizer in forum EditingReplies: 1Last Post: 16th Dec 2008, 18:39 -
Descriptions for Audio Effect Plug-ins-- Vegas 6.0d
By solarblast in forum AudioReplies: 4Last Post: 15th Nov 2008, 22:39 -
Sony Vegas, Windows Vista and DeBugmode Wax 2.0e
By tarrickb in forum EditingReplies: 0Last Post: 16th Aug 2007, 12:29
