I'm thinking of getting DVDSP (DVD Studio Pro from Apple) for the purpose of authoring 2-channel high-res audio DVDs. (Not DVD-As, but rather DVD video (audio only). The video will just be a still shot, but I want the audio to have 24 bit / 96 kHz quality. Will DVDSP allow this without subsampling the audio data?
Secondary question - My audio files are 24/96 AIFF files, can I just use these with DVDSP or will they need pre-processing?
Thanks in advance!
Tim
You need to pre-process with A.pack (if you want AC3 - limited to 16/48 ), which comes with DVDSP, or you can just leave it in AIFF, I believe, and DVDSP will make it DVD standard PCM audio. The DVD Video spec allows 24 bit, 96kHz audio (at least with PCM - the encoding method used by AIFF), but you will be limited to 6144kbps. Here's a brief reference site:
http://www.robertsdvd.com/video-audio.html
DVDSP does support Stereo PCM at 24/96, at 4608kbps, according to it's specs:
http://www.apple.com/dvdstudiopro/specs.htmlI like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 10:15 -
DVD to XVID and retain LPCM audio uncompressed
By rollo_tomasi in forum DVD RippingReplies: 8Last Post: 14th May 2010, 12:47 -
Re-Authoring A DVD With LPCM>AC3 Audio & Fewer VOBs
By DeathStalker77 in forum Authoring (DVD)Replies: 5Last Post: 25th Dec 2009, 12:25 -
Dvd Vobs: change audio from LPCM to AC3 2.0
By biancolone in forum Authoring (DVD)Replies: 3Last Post: 14th May 2007, 07:16
