  1. Member daamon's Avatar
    Melbourne, Oz
    I notice that putting a colon directly after a tool name stops the "automatic tool link" from picking up the tool name and so no link:
    e.g.:
    "...use VirtualDub:" or "...in DVDLab:"
    This following one is to see how it works with multiple words for a tool:
    "...and TMPGEnc DVD Author:"
    And with a different punctuation mark:
    "...with VirtualDubMod; ffmpeggui, or BeSweet:"
    EDIT: Having viewed the post, seems like you've got a problem with your colon Baldrick...
    Also, the test with the full name of TDA gives a link to TMPGEnc (the encoder) - to be expected, though not desired.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
    i added the colon because it messed up something...don't remember what right now.
  3. Member daamon's Avatar
    Melbourne, Oz
    OK, fair enough.
    As a cheeky aside, any likelihood of this one coming to fruition?
    https://www.videohelp.com/forum/viewtopic.php?t=209342&highlight=
    Or does your comment "daamon: Just send me the php code so i can add it....." mean that it's a lot of work / future task...?
    Carpe diem.
