This is odd... I've been converting d/l'd DivX files to VDC format to put on discs to play in my DVD player. Converting a 45min. DivX file to MPEG-1 CBR at 480kb/s with Ghost Reduction, Noise Reduction and Sharpen Edge options turned on took about 3.5 hours on my P-III 550 (o/c'd to 770Mhz) with 256MB RAM and a 120GB RAID5 disk array. I recently put together an Athlon XP 1800+ system with 1GB of RAM and a 20GB HD relegated my other machine to the position of file server. When I attempted to pick up where I left off with the encoding, I figured it would be much faster. However, it is taking exactly the same amount of time. At first, I thought it might have been because I was trying to access the source file through my network and then write the destination file back through the network, so I pulled the source file to the local disk and also wrote to the local disk with no change in encoding speed. To top it off, I'm now getting artifacts all over the screen. This never happened on the P-III. Help? Anybody? Suggestions?
Results 1 to 1 of 1
Windows 7 is out, have you upgraded?
By Baldrick in forum PollsReplies: 84Last Post: 6th Jan 2012, 17:56 -
I upgraded an old PC and use it to rip BDs
By barkinglama in forum Newbie / General discussionsReplies: 37Last Post: 30th Sep 2010, 19:36 -
Upgraded Ram memory?
By neworldman in forum ComputerReplies: 13Last Post: 25th Jul 2010, 23:24 -
Have you upgraded to a HD camcorder?
By Baldrick in forum PollsReplies: 18Last Post: 8th Nov 2009, 20:36 -
Have you upgraded to WIFI N yet?
By yoda313 in forum PollsReplies: 14Last Post: 25th Jun 2007, 20:16
