Hi,
I have been looking arround with no success for an easy way to convert NTCS to PAL. ffmpeg don't work for me and I want a more easy application for this. Any ideas?
Also when I am using DVD2one it happends that toast 6 tells me that the media is 4.5Gb and the DVD is only 4.5Gb. The DVD is 4.7Gb,, whats going on??
Results 1 to 28 of 28
It's the same reason othat 30 gig harddrives only actually have approx 28 gigs of space i.e. 1000 does not equal 1024.
So your DVD is advertised as 4.7gig, but actually only has a approx 4.4gig capacity. -
You can only fit 4.377 GB on a DVD-R (4700000000 bytes). The math goes like this:
4700000000 bytes / 1024 bytes/kilobyte / 1024 kilobytes/megabyte / 1024 megabytes/gigabyte = 4.3772 gigabytes. Basically, they count 1000 B/KB, 1000 KB/MB and 1000 MB/GB, when it should be 1024. I'm guessing it was a decision made by their marketing departments.I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
Ok thanks
Now I just nead to know a nice app for the converting NTCS to PAL then my day is saved
I think MPEG2Works might be what you're looking for.
You'll need the registered version of MPEG2 Works. Once you register you are sent a link to download the registered version.
just a note.. i was just looking at the interior (the bundled binaries) for mpeg 2 works.. first off they are grossly breaking the law (unless they have some mpeg liscencing agreement) by bundling mpeg2enc inside their app. second they are using movtoy4m as the decoder (only one i see there) which means you need quicktime mpeg-2 decoder to re-encode mpeg-2 (vob) files... on top of that last i checked if you feed a 4+ gig mpeg-2/vob file through quicktime as a decoder it will horribly choke on the file and give you output that is not in any way shape or form useable (just my two cents b4 u go spending money on the program)
As below, so above and beyond, I imagine
drawn outside the lines of reason.
Push the envelope. Watch it bend.
Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind. -
Are they breaking any laws (rather copyright licenses) if the included GPL tools are unmodified, and they achnowledge them, and offer to provide their source code?
>>> bilestyle
Im NOT breaking ANY law...You can check here before You post something like that:
http://www.gnu.org/licenses/gpl-faq.html#GPLInProprietarySystem
Your presumtions are wrong......means you need quicktime mpeg-2 decoder to re-encode mpeg-2 (vob) files... on top of that last i checked if you feed a 4+ gig mpeg-2/vob file through quicktime as a decoder it will horribly choke on the file and give you output that is not in any way shape or form useable..
And here is the DISCLAIMER for those Tools which pops up during .DMG mounting...You see "GUI wrapper" and "running outside the MPEG2 Works" thing?..
DISCLAIMER
MPEG2 Works is a GUI wrapper /Graphical User Interface/ for freeware Unix tools developed by third parties and running outside the MPEG2 Works application listed hereafter, and You MUST agree with GNU GENERAL PUBLIC LICENSE to use those tools:
mpeg2enc
mplex
mp2enc
(CVS Aug 15, 2002)
© 2000-2002 Rainer Johanni, Andrew Stevens, Gernot Ziegler, Xavier Biquard, Ronald Bultje et al.
Altivec optimizations by James Klicman
http://sourceforge.net/projects/mjpeg
yuvscaler
(CVS Sep 24, 2002)
© 2001-2002 Xavier Biquard
movtoy4m
movtowav
(v4 Apr 24, 2003)
© 2002-2003 Johan Lindström
a52dec
© 2000-2002 Aaron Holtzman, Michel Lespinasse et al.
http://sourceforge.net/projects/libmpeg2
mpgtx
© 2001-2002 Laurent Alacoque, Philipp Biermann
http://sourceforge.net/projects/mpgtx
mplayer
© 2000-2003 Arpad Gereoffy et al. (ported to OSX by Jan Devera, Klokan Petr Pridal and Tomas Hurka)
vcdxbuild, vcdxgen
© 2000-2002 Herbert Valerio Riedel
ifogen, tocgen
© 2000-2003 Scott Smith
bbDMUX
Brent Beyeler (beyeler@home.com)
speed increases by, Apachez and Christian Vogelgsang
mpeg2dec
Copyright (C) 2002-2003 Shoji Tokunaga
Version 2, June 1991
Copyright (C) 1989, 1991 Free Software Foundation, Inc.
675 Mass Ave, Cambridge, MA 02139, USA
Everyone is permitted to copy and distribute verbatim copies of this license document, but changing it is not allowed.
TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
0. This License applies to any program or other work which contains a notice placed by the copyright holder saying it may be distributed under the terms of this General Public License. The "Program", below, refers to any such program or work, and a "work based on the Program" means either the Program or any derivative work under copyright law: that is to say, a work containing the Program or a portion of it, either verbatim or with modifications and/or translated into another language. (Hereinafter, translation is included without limitation in the term "modification".) Each licensee is addressed as "you".
Activities other than copying, distribution and modification are not covered by this License; they are outside its scope. The act of running the Program is not restricted, and the output from the Program is covered only if its contents constitute a work based on the Program (independent of having been made by running the Program). Whether that is true depends on what the Program does.
1. You may copy and distribute verbatim copies of the Program's source code as you receive it, in any medium, provided that you conspicuously and appropriately publish on each copy an appropriate copyright notice and disclaimer of warranty; keep intact all the notices that refer to this License and to the absence of any warranty; and give any other recipients of the Program a copy of this License along with the Program.
You may charge a fee for the physical act of transferring a copy, and you may at your option offer warranty protection in exchange for a fee.
2. You may modify your copy or copies of the Program or any portion of it, thus forming a work based on the Program, and copy and distribute such modifications or work under the terms of Section 1 above, provided that you also meet all of these conditions:
a) You must cause the modified files to carry prominent notices stating that you changed the files and the date of any change.
b) You must cause any work that you distribute or publish, that in whole or in part contains or is derived from the Program or any part thereof, to be licensed as a whole at no charge to all third parties under the terms of this License.
c) If the modified program normally reads commands interactively when run, you must cause it, when started running for such interactive use in the most ordinary way, to print or display an announcement including an appropriate copyright notice and a notice that there is no warranty (or else, saying that you provide a warranty) and that users may redistribute the program under these conditions, and telling the user how to view a copy of this License. (Exception: if the Program itself is interactive but does not normally print such an announcement, your work based on the Program is not required to print an announcement.)
These requirements apply to the modified work as a whole. If identifiable sections of that work are not derived from the Program, and can be reasonably considered independent and separate works in themselves, then this License, and its terms, do not apply to those sections when you distribute them as separate works. But when you distribute the same sections as part of a whole which is a work based on the Program, the distribution of the whole must be on the terms of this License, whose permissions for other licensees extend to the entire whole, and thus to each and every part regardless of who wrote it.
Thus, it is not the intent of this section to claim rights or contest your rights to work written entirely by you; rather, the intent is to exercise the right to control the distribution of derivative or collective works based on the Program.
In addition, mere aggregation of another work not based on the Program with the Program (or with a work based on the Program) on a volume of a storage or distribution medium does not bring the other work under the scope of this License.
3. You may copy and distribute the Program (or a work based on it, under Section 2) in object code or executable form under the terms of Sections 1 and 2 above provided that you also do one of the following:
a) Accompany it with the complete corresponding machine-readable source code, which must be distributed under the terms of Sections 1 and 2 above on a medium customarily used for software interchange; or,
b) Accompany it with a written offer, valid for at least three years, to give any third party, for a charge no more than your cost of physically performing source distribution, a complete machine-readable copy of the corresponding source code, to be distributed under the terms of Sections 1 and 2 above on a medium customarily used for software interchange; or,
c) Accompany it with the information you received as to the offer to distribute corresponding source code. (This alternative is allowed only for noncommercial distribution and only if you received the program in object code or executable form with such an offer, in accord with Subsection b above.)
The source code for a work means the preferred form of the work for making modifications to it. For an executable work, complete source code means all the source code for all modules it contains, plus any associated interface definition files, plus the scripts used to control compilation and installation of the executable. However, as a special exception, the source code distributed need not include anything that is normally distributed (in either source or binary form) with the major components (compiler, kernel, and so on) of the operating system on which the executable runs, unless that component itself accompanies the executable.
If distribution of executable or object code is made by offering access to copy from a designated place, then offering equivalent access to copy the source code from the same place counts as distribution of the source code, even though third parties are not compelled to copy the source along with the object code.
4. You may not copy, modify, sublicense, or distribute the Program except as expressly provided under this License. Any attempt otherwise to copy, modify, sublicense or distribute the Program is void, and will automatically terminate your rights under this License. However, parties who have received copies, or rights, from you under this License will not have their licenses terminated so long as such parties remain in full compliance.
5. You are not required to accept this License, since you have not signed it. However, nothing else grants you permission to modify or distribute the Program or its derivative works. These actions are prohibited by law if you do not accept this License. Therefore, by modifying or distributing the Program (or any work based on the Program), you indicate your acceptance of this License to do so, and all its terms and conditions for copying, distributing or modifying the Program or works based on it.
6. Each time you redistribute the Program (or any work based on the Program), the recipient automatically receives a license from the original licensor to copy, distribute or modify the Program subject to these terms and conditions. You may not impose any further restrictions on the recipients' exercise of the rights granted herein. You are not responsible for enforcing compliance by third parties to this License.
7. If, as a consequence of a court judgment or allegation of patent infringement or for any other reason (not limited to patent issues), conditions are imposed on you (whether by court order, agreement or otherwise) that contradict the conditions of this License, they do not excuse you from the conditions of this License. If you cannot distribute so as to satisfy simultaneously your obligations under this License and any other pertinent obligations, then as a consequence you may not distribute the Program at all. For example, if a patent license would not permit royalty-free redistribution of the Program by all those who receive copies directly or indirectly through you, then the only way you could satisfy both it and this License would be to refrain entirely from distribution of the Program.
If any portion of this section is held invalid or unenforceable under any particular circumstance, the balance of the section is intended to apply and the section as a whole is intended to apply in other circumstances.
It is not the purpose of this section to induce you to infringe any patents or other property right claims or to contest validity of any such claims; this section has the sole purpose of protecting the integrity of the free software distribution system, which is implemented by public license practices. Many people have made generous contributions to the wide range of software distributed through that system in reliance on consistent application of that system; it is up to the author/donor to decide if he or she is willing to distribute software through any other system and a licensee cannot impose that choice.
This section is intended to make thoroughly clear what is believed to be a consequence of the rest of this License.
8. If the distribution and/or use of the Program is restricted in certain countries either by patents or by copyrighted interfaces, the original copyright holder who places the Program under this License may add an explicit geographical distribution limitation excluding those countries, so that distribution is permitted only in or among countries not thus excluded. In such case, this License incorporates the limitation as if written in the body of this License.
9. The Free Software Foundation may publish revised and/or new versions of the General Public License from time to time. Such new versions will be similar in spirit to the present version, but may differ in detail to address new problems or concerns.
Each version is given a distinguishing version number. If the Program specifies a version number of this License which applies to it and "any later version", you have the option of following the terms and conditions either of that version or of any later version published by the Free Software Foundation. If the Program does not specify a version number of this License, you may choose any version ever published by the Free Software Foundation.
10. If you wish to incorporate parts of the Program into other free programs whose distribution conditions are different, write to the author to ask for permission. For software which is copyrighted by the Free Software Foundation, write to the Free Software Foundation; we sometimes make exceptions for this. Our decision will be guided by the two goals of preserving the free status of all derivatives of our free software and of promoting the sharing and reuse of software generally.
NO WARRANTY
11. BECAUSE THE PROGRAM IS LICENSED FREE OF CHARGE, THERE IS NO WARRANTY FOR THE PROGRAM, TO THE EXTENT PERMITTED BY APPLICABLE LAW. EXCEPT WHEN OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR OTHER PARTIES PROVIDE THE PROGRAM "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK AS TO THE QUALITY AND PERFORMANCE OF THE PROGRAM IS WITH YOU. SHOULD THE PROGRAM PROVE DEFECTIVE, YOU ASSUME THE COST OF ALL NECESSARY SERVICING, REPAIR OR CORRECTION.
12. IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN WRITING WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MAY MODIFY AND/OR REDISTRIBUTE THE PROGRAM AS PERMITTED ABOVE, BE LIABLE TO YOU FOR DAMAGES, INCLUDING ANY GENERAL, SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES ARISING OUT OF THE USE OR INABILITY TO USE THE PROGRAM (INCLUDING BUT NOT LIMITED TO LOSS OF DATA OR DATA BEING RENDERED INACCURATE OR LOSSES SUSTAINED BY YOU OR THIRD PARTIES OR A FAILURE OF THE PROGRAM TO OPERATE WITH ANY OTHER PROGRAMS), EVEN IF SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
END OF TERMS AND CONDITIONS
[/quote] -
...and You can find this on the top of MPEG2 Works web page:
"...These bundled tools are easily available on the internet and if you are skilled enough then buying the GUI is not necessary..."
LOT of people visiting this forum...And there is a LOT of readme and how to's for various task involving MPEG format, like Galactica's tutorials here...So EVERYONE can find a free solution for almost everything...But some people does not want to work in Terminal...I made the GUI wrapper for them and those people are kind enough to support my work and knowledge... -
I am thankful for your hard work on this, as it really opens up those tools for use by many more people. It's crucial to have your tool to point people to for certain conversions they are trying to make. Thanks Serbian, for making this great tool, and it really fills a huge void in the MPEG utilities section of available Mac software. I'm glad you know where you stand regarding all the licensing issues for all those GPL tools.
so explain why every other program that uses mpeg2enc goes to extraordinary lengths NOT to bundle it with their software (mediapipe - compiles the SOURCE on the fly, forty-two (built with the installer), ffmpegX-downloads then installs) do you think that is for fun? im not saying that its an infringment of the GPL im saying its an infringment of mpeg licensing. Listen im not trying to bust your balls for trying to make some money of something that makes peoples lives easier, i know what its like to develop software and then hear gripes from ungrateful users (granted i have no use for your software because i know all the tools involved better than most people) all im pointing out is from my knowledge and anyone i've ever worked with, you cant bundle a compiled mpeg2enc with your software without proper licensing, which is cost-prohibitive for most people.
Oh yeah, MPEG licensing, didn't think about that one...
now keeping in mind that using qt as the decoder (which DOES create problems with files over 4 gigs.. i dont care what anyone says, its not a limitation that can be fixed short of how i did it in afropic) i just posted a thread at mediapipe forums showing how to change the framerate from PAL to NTSC... here is the thread.. if you need me to make an updated version to do vice versa let me know.. but this is one of the only successful ways to change framerates.
http://mediapipe.sourceforge.net/Forum/viewtopic.php?t=551As below, so above and beyond, I imagine
Well, I dont find the mpeg2works doing a good job anyway
Tried two times to convert now, an d both times ther'e an apple script error after 1-4 hours.
My machine is a G4 Quicksilver 867Mhz with OS X 10.3.3 running.
Maybe I have to start looking at fmpeg again
Again...My app DOES NOT do encoding...mpeg2enc does...And it is under GPL...And everyone has the right to use it and distribute it as long as it puts GNU license with it...I sow from Your link that You worked with Mr. major...I wish You best in Your work and I hope You will be able to make ultimate MPEG tool on a Mac...But, please, during Your developing, leave others some space to work too...
Regarding errors....Use DVD Converter bundled with M2W for NTSC<>PAL conversions, not MPEG2 Works and Your VOB must have AC3 or MP2 sound and You have to rip it with OSEx in one big VOB file as described on MPEG2 Works forum...Also, if You have any other questions regarding Your problem, please use MPEG2 Works forum for that or send me a message via mail... -
you REALLY dont get it do you.. ffmpegX doesnt do the encoding, mediapipe doesnt do the encoding, nor does 42 or any other app that has put to use mpeg2enc. Ive been coding in this scene ALOT longer than you have (clearly by your complete lack of understanding) and i KNOW your app is no more than a bunch of applescripts slopped together over a bunch of powerful GPL tools... .. its NOT ABOUT THE F$*CKING GPL its about MPEG LICENSING. but you know what, im just trying to be nice and let you know a fault you have clearly made. im not trying to call you out.. but if you are going to be a braying moron about it then i hope you get called on it.
Dont use that language, please...Do Your coding and forget this discussion...
I am using the mediapipe recipe from the lead above, and the conversion is going well. But exactly how to set the mpeg encoder, as the long string of numbers have no meaning. I am trying to convert pal 16:9 to ntsc 16:9. so is the string same as in mediapipe discussion?
i dont have any 16:9 material to test but im pretty certain if u substitute "a -3" (without quotes of course) for -a 2 in the mpeg2enc line and "-A 32:27" in place of whatever -A line in the ppmtoy4m line you should be okay.. although im not sure if the -A line is generated according to the source material u insert, so that could be off.... when u add mpeg encoder u can choose generate arguments, change 4:3 to 16:9 to see what it will give u for -A in the ppmtoy4m and then use the exact lines i provided in the other thread and just change mpeg2enc -a 2 to -a 3 and whatever it gave u for -A in the ppmtoy4m when u changed to 16:9 before.. i know this sounds confusing but its the best way i can put it.
if you want, i can send you some clips of "16:9" material for your tests.
just say the word and its done. -
Automatic Arguments generated by mpeg2en is a little different than yours. Specifically , the last one was Q something , not M something.
Does it matter for 16:9?
I actually had already finished one video file through mediapipe, using the exact arguments in the mediapipe forum lead (see above link), the end result was the image a little elongated, a little longer face than original.A rectangular dialogue box in the beginning in the movie appeared as square in stead of rectangle.
So i am redoing the whole thing with the automatic arguments generated in the mediapipe.
So after the video is done, do i run the mediapipe again to extract the ac3,and use the audio file and video file to contruct the dvd?
Or do i have to go through one more round of conversion before dvd composition(dvd studio pro or others?) -
Sorry, not mpn file, it was mpv file, viewable by quicktime player , and videolan. But if i use quicktime to convert it to mv2, it will take another 24 hours. I thought mpv is already a mpeg 2 file, so how can i combine that with ac3 file to make it into dvd?
By using DVD Studio Pro or the freeware Sizzle.
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
Current DVD Recorders in both PAL+NTCS available?
By 1234567 in forum Newbie / General discussionsReplies: 4Last Post: 8th Jan 2010, 18:30 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 02:47 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 15:36 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 14:47
