    Sep 2001
    sweden
    I am going to burn some vcd, what software is the best.
    I want good quality.
    I have some divX, some MPEG and MPEG layer-3. I could not tell the diffrent. Do i need more than one software.
    ps i use win XP.
    Thanx
  2. You can't just burn any old file into a VCD. You will have to have encoded it and authored it correctly first.
    <-- Read the guides on this site to get a better idea (menu to your left).
    Regards.
    Michael Tam
    w: Morsels of Evidence
    Sep 2001
    sweden
    I heard that the TMPGEnc does not whit the win XP is that true??
    When i have converted the file to vcd, then what is the best burn software.
    I mean what do you think is the best??
  4. Don't know about the TMPGEnc and WinXP thing.
    Once you've converted it to VCD compliant MPEG-1, it depends on what you want to do.
    If all you are interested in is a simple one track VCD, then most software will do it just fine (e.g., Nero, Easy CD Creator, WinOnCD, VCDImager+CDRDAO/CDRWin, etc.)
    Regards.
    Michael Tam
  5. If quality is really your concern, maybe you should consider SVCD instead? You get less storage space, but the quality is a bit better (about the same as SVHS).
