Here you can see its seeing that its 44.1, but it just passes it up. Any reason why. Is it because of the horiz res?
Code:############### New MPEG File ############### File: C:\Downloads\Chris\download\torrent\SNL_Jeopardy\Connery_Cage_Flockhart.mpg Type: VCD Horizontal Res: 320 Standard: NTSC Audio SampleRate: 44100 ******** Demultipexing original mpg file (Total size: 56MB, Duration: 00:00:20, Rate(MB/Min): 166.83) ******** Resampling audio from 44.1 KHz to 48 KHz Skipping.... ******** Trimming start of video ES - Nothing to do. ******** Multipexing elementry stream
Have you told it to skip the resampling?
CAn you make a sample with the MakeSample tool (from the menu) & send it to:
ftp://svcd2dvd:Upload@ftp.svcd2dvdmpg.com:7676/dns-tommy/SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I made the sample and ran a test on it, it worked. So i ran just one mpeg, it worked too. Now im gunna test the whole thing again. Hmmm maybe im just stupid :/
Audio freq response on various DVD speed settings? - HELP!
By will7370 in forum AudioReplies: 2Last Post: 12th Jul 2010, 16:05 -
Converting tv shows audio
By Oem in forum AudioReplies: 3Last Post: 1st Feb 2010, 22:42 -
No Audio after converting
By Seff7845 in forum AudioReplies: 1Last Post: 30th Sep 2009, 05:52 -
No audio converting flv
By holywoodhawk in forum Video ConversionReplies: 0Last Post: 11th Aug 2009, 23:38 -
(Completed): MMC capture results in 44100 sample freq instead of 48000.
By palouse in forum Capturing and VCRReplies: 14Last Post: 23rd Oct 2007, 16:47
