Results 1 to 9 of 9
    Dec 2002
    Singapore
    I have a DVD-R (Imation / burned on Pioneer A05) that is full of MP3 files.
    Unfortunately, I no longer have these on my hard drive and when I try and read from the DVD-R, I can see the directory structures and files but cannot play or copy the actual files.
    Has anyone any ideas how I can recover this data........
    Chris
  2. Member richdvd's Avatar
    Oct 2003
    Toronto, Canada
    what error do you get when you attempt to copy them to your hard drive?
    Dec 2002
    Singapore
    No specific errot message - it just wont open the files (using itunes for example) or copy. The disc keeps trying to be read......
  4. Member richdvd's Avatar
    Oct 2003
    Toronto, Canada
    could be bad media
  5. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    Try cleaning the disk
    try using a different dvd-rom drive to read
    try isobuster
    try copy and paste in windows explorer
    try dvdinfopro to confirm if theres read errors on the disk
    there are many threads about this topic in here
    Dec 2002
    Singapore
    Tried cleaning the disc and using another PC with no luck.
    Have started to try isobuster - its sees two trees (one ISO and one not). I seem to get sector read errors when I try and extract. Will try again.......
    Not tried DVDInfopro yet - Thanks.......
  7. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Can you copy the ISO to your hard drive and read it with ImgTools?
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
    Dec 2002
    Singapore
    Just tried DVDInfopro and get read errors......
    Error - LBA = 00049d20h and onwards.... Looks like it starts to have problems after about 14% of the disk read.
    Is there any hope for me or should I just give up and put it down to bad experience (and not use Imation media again !!!)
  9. Member Sifaga's Avatar
    Aug 2003
    very little hope i would say,
    even if you did get the corrupt files off they may not sound right
    i had the same prob and between copy/paste and isobuster i managed to get some of my MP3's back.
    i ended up copy/paste individual songs, and isobuster individual song, if a read error i would just try the next one
