Hello,
I have an external 4x DVD Burner from Pacific Digital. I'm using Verbatim DVD-R's. I'm using DVD Decrypter to burn my DVD-R's.
My problem is that when I read from a DVD-R and then write to a DVD-R the disc wants to freeze up towards the end of the program. It's like it's not reading the last half when it's writing. Does anyone know why this is or how I can fix the problem? It would be greatly appricated. I've recorded other authored DVD's and they work fine. It's just the stuff that's on DVD-R.
Thanks,
thebuddy
PS. Sorry if this is in the wrong forum.
Usually a bad burn due to bad media and not reading towards the end of the disc.Cant fix bad burns.
Try shrinking your movie down a little more to compensate for your possible bad media. Perhaps down to 4.2gig rather then the usual standard of 4.4gig.
I've tried Maxell and got the same results.
I'm not sure if the media is to blame or not. I have a Panasonic Stand Alone Recorder and I use Verbatim discs on that and have no problems what so ever. The discs play fine.
A dumb question: how do I shrink my movie down to a 4.2 gig? -
+R disc have about 3,000 fewer sectors than -R. Shrinking is probably the answer. You should be able to use Shrink to rip the -R and then reauthor with a different maximum output size.
I have DVD Shrink. I still don't know how to use it correctly. Is there a turorial that I could go to that would show me how to shrink, rip, and reauthor with a different maximum output size?
Here's a link to get you started. It's the simpliest one I could find but there are several in the guides section og this forum.
http://www.dvd-guides.com/guides.php?category=dvdcopy&name=shrink
Specifically what you want is in the Edit-Prefernces tab of Shrink 1.7 where it allows to to set a "custom" output size.
Trying to burn a dvd using dvd shrink and Nero 10, please help a newbie?
By KtuluAlly in forum DVD RippingReplies: 6Last Post: 30th Dec 2010, 14:33 -
newbie having problems with SUPER ©
By emb36206 in forum Newbie / General discussionsReplies: 6Last Post: 2nd Nov 2010, 06:04 -
translate yiddish dvd to english dvd-is this possible? From a newbie.
By humblejohn38 in forum Newbie / General discussionsReplies: 2Last Post: 17th Sep 2010, 06:20 -
DVD to storage drive, best media player for dvd playback- newbie questions
By omkls08 in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2009, 11:22 -
Newbie's DVD burner isn't recognizing DVDs as burnable (Both DVD+/-R)
By OhGodHelpMe in forum Newbie / General discussionsReplies: 9Last Post: 30th May 2007, 09:48
