Knocked out 8 copies yesterday, no problems, using shrink alone and re-authoring just to get a 100% of main movie only.What program is burning these? I didnt think shrink had a burner, am I mistaken. Seems pretty automatic, as soon as I encode to hard drive, automatically asks me to insert blank media, then burns without a hitch. I really am a dummy and have no idea what I'm doing.....
what version of shrink are you using,
i think it burns using Nero and you can burn an ISO using DVDDecrypter -
I have Nero, but didnt know it did it automatically.....Learn something new everyday
If you have Nero on your system, Shrink can do a terrific job of automatically stating up Nero, and handling all of the settings for you. This is actually an option you can choose in the preferences menu of Shrink. I think it says something like:
"Enable burn using Nero."
I have a friend who is having problems with this... when she chooses this option, it does NOT work. It does for me, and for a couple of friends, though. On hers, Shrink merely encodes, and then informs her it is done. She then has to close Shrink, and manually start Nero, and drag the proper files into the required "video" folder. Not certain why, since she has the exact same versions of Nero and of Shrink, and even the same system that I have. The only difference that I can think of... she had a "lite" version of Nero installed first, before she upgraded to the full-fledged suite version (the one that I had). Maybe the Windows Registry is getting confused, and thinks she still has the "other" version. Who knows?
-Bruce in Chi-Town -
BSpielbauer
might wanna try lookin at where the output file is going. make sure the dvdr drive is selected.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
Can't rip already backed up DVD, tried imgbrn, DVD shrink, DVD decrypter...
By perceptionist in forum DVD RippingReplies: 10Last Post: 27th Sep 2010, 00:52 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 22:31
