  1. i went to download a zip file earlier today and i accidentally told IE to open them all, instead of download them. i know i can right click on zip files and download them most of the time, but sometimes that option isnt available. i've tried screwing around with IE but i cant figure anything out. i want it to bring up the normal dialogue when i click on zips, not just automatically open them.
    thanksssssssss
  2. Same thing happened to me a few weeks ago. I ended up having to uninstall WinRAR then click the DL again and recheck the box. Then reinstalled WinRAR and all is well at the monent
    Rick
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    winxp handling of zip files sucks ...
    do this:
    To Disable:
    1) Start Menu > Run
    2) Type:
    regsvr32 /u %windir%\system32\zipfldr.dll
    To Enable:
    1) Start Menu > Run
    2) Type:
    regsvr32 %windir%\system32\zipfldr.dll
  4. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    Do you get the normal download dialog box when you right click on a zip file, or is this just when you double-left-click on a zip file. Another thing you might check is right-click on My Computer, chose Explore, Tools, Folder Options, File Types. Scroll down to ZIP and see if there is an association with that file type.[/img]
