IM having teh same problems as i did with the beta versions of the upgrade. First of all, when i upgrade, the screen shows funny wuzzy lines, its like not in english, its a big lite on banner, but the parts that are suppost to say "updating, fflashing, etc" come out as garbled. (which was the same way the beta update did it). Then, when i put in any disk, it reads it but the volume is snap, crackled, and popped, i duno why. it was also this way with the beta update, if someone else has had this problem , please help. i know my disks are good b/c with the 2.9 update, its just fine, no snapping or crackling in volume ?
I posted on divx.com and nobody else has the same problem?
http://forums.divx.com/viewtopic.php?topic=57976&forum=21
ty
Results 1 to 1 of 1
PotPlayer 1.5.29490 Beta Subtitle Problems
By ved_kuro in forum SubtitleReplies: 0Last Post: 25th Aug 2011, 10:04 -
Lite-on DD-A100GX firmware upgrade?
By perceptionist in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Feb 2011, 04:45 -
k-lite mega pack codecs 6.30 problems...
By sgbd in forum Software PlayingReplies: 10Last Post: 2nd Sep 2010, 05:46 -
Audio codec problems after installing K-Lite and ffdshow
By iggie in forum AudioReplies: 6Last Post: 17th Dec 2008, 07:39 -
Codec problems after installing k-lite
By woolf-gang in forum Software PlayingReplies: 9Last Post: 28th Sep 2007, 09:56
