I was looking through this website and went to look at my DVD Player to see if it could play DVD-RW or not. I found my answer, but also came across the only hack it has. The only problem is that it is in Spanish. When I translate it with programs it comes out almost uncomprehensible.
Is there anyone who could reply and translate what it says to do?
1- encender (star) el dvd con la tecla enter del panel frontal apretada ( tur off, and star de dvd player then press enter swicht, to front panel)
2-apretar en el siguiente orden en el control remoto 8,9,2,6 ( press to remote unit 8,9,2,6)
3- apretar 0 para multizona . ( press 0 to multizone)
4- apretar open/close 8press open /close)
5- finalizado ( finish)
If everything is infinite then nothing is definite.
1) Start the DVD player while holding down the "enter" button/switch on the front panel
2) Press the following buttons in this order: 8,9,2,6
3) Press "0" to enable the multiregion hack
4) press "open/close"
5) Finished
Even in Spanish it isn't very clear, but that should do the trick. -
Thanks for the help. It's for my DV3000C. I'm not sure if it worked, but at least I tried.
If everything is infinite then nothing is definite. -
That's not Spanish, that's Spanglish. Seriously.
Yeah, it was a little confusing. I assumed the words in parentheses were the translations he had already attempted.
How to remove spanish audio?
By skorpinok in forum Video ConversionReplies: 1Last Post: 6th Jan 2012, 10:06 -
embed spanish subs... need some help here
By afteryouwho in forum ffmpegX general discussionReplies: 10Last Post: 17th May 2011, 05:19 -
English subtitles to Spanish DVD
By john2010 in forum SubtitleReplies: 1Last Post: 3rd Mar 2010, 06:07 -
Getting spanish only.
By Fiostech in forum Blu-ray RippingReplies: 2Last Post: 3rd Feb 2009, 19:54 -
Removing Spanish soundtrack?
By lowfell in forum Authoring (DVD)Replies: 3Last Post: 31st Mar 2008, 11:39
