I can't seem to get this ripped. It gets up to 49% and then has read errors. I cleaned the disc and looked it over and don't see anything that would cause this on the physical media.
So far I used DVD Decrypter, SmartRipper, and DVDXCOPY. All 3 stopped at 49%.
Has anyone else copied this sucessfully? It is the first disc in the series.
Coincidentally I'm in the process of backing up Taken myself, I'm on disk 3 with no problems using DVDShrink 3.1.7. Are you using a seperate reader from your burner? If so try using your burners reader. Also, have you tried playing Disk 1 yet, maybe it's bad? You can also try DVDecryptor in "brute force" mode.
Originally Posted by GKar
I'm using my burner as my reader.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
