  1. hey guys when i try to cut an mpeg with tmpgenc it locks up
    i could cut fine up till last week
    it doesnt matter if the mpeg was captured or encoded it has same results
    as soon as i start to drag the slider bar it locks up any help would be apreciated
  2. Member daamon's Avatar
    Melbourne, Oz
    Hi Bootdsk,
    Have you changed your system (PC setup) in between it working and not working? Or, you may have picked up a virus...
    Try Womble MPEG2-VCR...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Member richdvd's Avatar
    Oct 2003
    Toronto, Canada
    maybe try re-installing the software.
