i got this movie in a .avi format and i can play it on my DIVX player, but when i convert it to a mpeg so i can burn it as a vcd i cant play it anywhere. when i try to play it i can see the very start of the movie but then the picture goes away but the sound continues.
any ideas?
Results 1 to 19 of 19
Bad Frames ?
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
the results of gspot:
86% is video data, 14% is audio
Video:
4CCX50/divx Name
ivX5.0
bitrate: 1162kb/s FPS: 23.97 Qf: 0.237 bit/pixel
Audio:
Name: 0x0055(MP3) ID'd as MPEG-1 Layer 3
bitrate: 183 kb/s Fs: 48000Hz -
Its a divx file with mp3 audio. Check for bad frames using Vdub.
Before you do anything else you should still check the avi for bad frames as VCDHunter suggested. You still haven't ruled that out as being the problem unless you failed to mention it.
I realize the 4cc indicates that it's Divx video but I can't help but suspect it's really Xvid. I've never seen a Divx file that has a 23.976 frame rate and VBR audio. This is not to suggest that it's impossible to encode as such because it obviously is possible, but not at all common. I think it was encoded as Xvid and set up to utilize the DX50 4cc.
The most "TMPGEnc friendly" Xvid decoder is FFDSHOW. Try installing that and try encoding again with TMPGEnc. BUT, due to the fact that the avi has VBR audio you must decompress it to PCM wav. To do this just open the avi in Vdub, go to "audio" and select "full processing mode", go to file and select "save WAV" and wait for your wav file to be created. You will then use the wav file as your audio source in TMPGEnc. -
oh sorry, i already checked for bad frames but it said everything was good
i tried changing the audio into a wav then used TMPG to make a mpg so i could turn it into a vcd, but it would only show the beginning then the picture rather stops or goes away but the audio keeps going
if i move to another spot on the movie the picture shows up for that frame but doesnt move after, but the audio continues
i have no idea what to do, never happened to me before -
Originally Posted by eternalblu"Art is making something out of nothing and selling it." - Frank Zappa
Originally Posted by ZippyP."Art is making something out of nothing and selling it." - Frank Zappa
well after trying out everyone's suggestions i have not been able to solve my problem, so im just gonna leave it i guess and try to download another version
that seems the easiest way
but thanks to everyone for trying to help
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
MT2S files play video in MPC but no sound+Ultra Cyberdvd wont display video
By btvs2000 in forum Software PlayingReplies: 7Last Post: 22nd Sep 2008, 15:44 -
no video but sound playing video with MPC
By majax79 in forum Software PlayingReplies: 5Last Post: 30th Mar 2008, 03:05 -
no video but I got sound
By marzipan in forum Newbie / General discussionsReplies: 2Last Post: 24th Aug 2007, 11:35
