  1. when i try using canopus procoder 1.5 for converting files to dvd format, i get something like a .mp2 file or something similar and everytime i try to burn using that format, i get an error. is there a way to have canopus procoder convert to a dvd compliant .mpg? thanks
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    Procoder is just an encoder, not a DVD author. Assumig you used the DVD template, the m2p file that was create is DVD compliant. You need to use a seperate program to create the proper DVD file structure such as TMPGEnc DVD Author, DVD Lab or Ulead DVD Movie Factory. Click on the green "Author" button on the left for guides on how to do this.
  3. yea, i have adobe encore and dvd architect. when i burn using the file canopus creates, i get an error on my dvd player saying "check disk." when i burn using a file i created w/ tmpge, i get no problems.
    so any help now?
  4. Member teegee420's Avatar
    Dec 2003
    Southern California
    Does the DVD play on your PC with WinDVD, Power DVD or some other software DVD player?
  5. Banned
    Oct 2003
    Americas
    Procoder just like other encoders has an option to output to separate streams or "program" file that contains both =MPEG. Look for this feature in output options.
  6. yes it does play on my computer using power dvd, but it doesnt work on my crappy one in my room, or my sony dvd player
  7. Member teegee420's Avatar
    Dec 2003
    Southern California
    Just a guess but your problem might be media related.
