is there a program which i can make permanent subs on my ANIME dvd rips....i dont want to use vdub or vobsub...
THnax
Try FlaskMPEG. The best version to use would be FlaskMPEG 0.6prev1.1 "subtitled fixed" version. You can download it from doom9's site: http://www.doom9.net
All you have to do is to rip the vob files in their entirety (i.e., in "file mode" with SmartRipper or use DVD Decrypter).
Then load the relevant IFO in Flask and you get your choice of video, audio and subtitle streams.
Regards.
Michael Tam
w: Morsels of Evidence -
i have tryed DVDx and FLASKMpeg and they are tooo sloooooooowwwwwwww and the audio is to low
THNANX FOR TRYING -
ill just use VIRTUALDUB AND VOBSUB they are very good appz...i cant belive i doubted them for a second
As a minor note, FlaskMPEG (subtitled fixed version) is probably the best program to use for subtitles. It is absolutely flawless with pretty much every title you are likely to come across and you get to preview the subtitles before starting.
As for speed, it depends on the plug-in you are using.
Also with the audio, the audio output in FlaskMPEG is actually CORRECT. It sounds low because most audio CDs have the audio sampled too loud. If you want it louder, turn up the volume!
With DVD2AVI, you actually loose a bit of the dynamic range of the audio.
Regards.
Michael Tam
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
But I think this is not the case when using Azid for ac3 decoding!
Steve56
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 08:22 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 17:10
