  1. I suppose this is like a theory question.
    When you open a movie (using shrink), it sets the compression automatically, usally the main movie is about 50%.
    Of course by using the compression slider on the trailers, extras, and turning off subtitles, or DTS vs stereo, etc, this will allow the MAIN MOVIE to automatically go higher.
    In a nutshell, the overall compression keeps a constant 4.2 gig size.
    So my question is what happens when you COPY your copy.
    Does it recompress? Or since it's 4.2 to begin with (the copy), the compression is turned off? Is it still copy protected or can you use NERO and just dupe the DVD.
    thanks...
    Mar 2004
    Belgium
    The copy is not prootected, so you can do a dvd to dvd copy using Nero or whatever program you want.
  3. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Just use your regular burning software to put them on DVDr. If you created the title set with DVD Shrink or some similar app, it will fit.
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Yes.
    No.
    Yes.
    If in doubt, Google it.
  5. [quote="Never approach a computer thinking "This will only take 5 minutes".[/quote]
    Everytime I do, it the longest 5 minutes I always NEVER have.
