  1. I used Nero 6 to make data content DVD. Used DVD+R (imation 2.4x, memorex 4x), Khypermedia rebagged cyberdrive DX082D.
    DVD+R burned with no problem, but after burning, Win XP won't read it. Nero can see the session and track on the DVD+R, but XP keep giving me "not accessable, incorrect function" error message. Then I tried to do this on DVD+RW, and everything went well, XP reads the burned DVD+RW without problem.
    Being desperate, I used the image burner in Nero to burn the content to a .nrg image file, and used dvdDecrypter to burn the image to DVD+R. Again, it burned well but XP refuse to read the burned DVD+R.
    The question: Why I am having this problem with Nero/DVD+R combination? I have wasted 6 DVD+R discs tonight, and still have no clue. HELP!
    Oct 2003
    Sofia, Bulgaria
    I had many problems with first releases of Nero 6. Get the latest or try with Nero 5.5.10.56.
    My oppinion is that your media is good and it is no need to search different ones.
    Just comes in my mind: the writing and reading lasers of the drive are different. That means you should go to return or at least to check the hardware...
