Hi all.
Has anyone else experienced this with DVD Decrypter? I rip one DVD to my hard drive and it whizzes through in about 10-15 minutes. The next one, however, takes 2-3 hours. What's causing this?
Is the 15 minutes normal or the 2 hours? Or somewhere in between? Is there anything that can be done to make them all quicker?
Any ideas are appreciated.
HD
About 15 minutes on a 16 speed dvddrive is normal for a DVD9 (2 layers).
2 hours is not, was the disk dirty ? Were there any scratches ? Did decrypter report read errors ? -
The disk was relatively clean. Decrypter finished with no errors. It happens like every third disk.
HD -
Check to see if it's encrypted, and are you using your dvdrw to rip? Encrypted discs are usually locked at about 2x, but that's still quite long to be hitting 2-3 hours (unless you're exaggerating).
Otherwise make sure your discs are clean and your reader is clean. Or maybe you don't have 4-8 gigs of contiguous space on your hard drive, so it takes longer to arrange it if it's not defragmented. -
hallesdaddy, when you say the 1st takes 15 minutes and the next takes hours is the 15 minutes one just after power up, or has the machine been on a while.
My train of thought is along heat or memory lines. Shudder raises a good point about fragmentation. Could you try a test for us (or maybe you have already). Try ripping a movie as you normally do when you get the 15 minutes. Don't remove the disc and rip the SAME movie again saving under a different name (ie: Test-1 and Test-2). That would elinate the clean / dirty argument and may point to hardware.
Let us know what your times are. -
I think I figured it out. For some reason, it was alternating ripping to my C: drive, then to my D: drive, which is external. When it rips to my C: drive, no problem. Ripping to the D: drive slows it down.
Thanks for all the input, guys!
HD
Fast encoding on a slow computer
By si4h in forum Newbie / General discussionsReplies: 11Last Post: 5th Aug 2010, 11:09 -
DVD Decrypter / DVD Fab - Extremely slow ripping speeds in Vista
By awp in forum DVD RippingReplies: 5Last Post: 19th Dec 2007, 13:11 -
Divx won't fast forward fast! What's wrong?
By Hank Kinsley in forum Newbie / General discussionsReplies: 8Last Post: 23rd Jul 2007, 19:49 -
DVD Decrypter awful slow on new computer
By zainka in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2007, 11:24 -
.wmv movie file couldn't fast forward/fast seek?
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 20:43
