For those looking for good furniture for video storage, I found this:
http://www.storeyourmedia.com/detail.aspx?ID=7044
for DVD storage. I have about 1800 and most are in the slim 5.2mm CD cases so his cabinet can theoretically store 3000 slim cases. It's now a little less than 2/3 full. I had them all over the place and was always wondering where I'm going to keep them all long-term. I ordered the CD-1500CHY and last night this arrived and I put it together in about 90 minutes. It is one sweet-looking cabinet. The veneer version is only $22 more than the fake finish and it looks very nice. The hole tolerances are tight, the fasteners are all top quality and the back panels are finished on both sides in case you use it as a room divider. I highly recommend this place. The owner had even made a last-minute change for me when I discovered the veneer model, a new item. Check out some of the stuff they have. They pay UPS ground shipping too!![]()
Results 1 to 29 of 29
*Testimony paid for by Store Your Media and W3Stores*
Seriously though, it looks good, I only wish I had that many DVD's to fill it with. -
http://www.centurycdna.com/product.asp
This is what I have for CDs...Smile
Smile -
I wish it were a paid endorsementOriginally Posted by pacmania_2001
That 1800 I have is 2-years'-worth of capturing and burning. Where did the time go .....?
I know it sounds like a commercial, but the cabinet was nicer than I would have thought, cheaper too. It looks exactly like solid cherry which is way out of my price range
It isn't often I find a good web-based company that leaves me feeling like I got more than my money's worth.
I've seen that before. Problem for me is I'd need twenty of those, at $4,000
I'll try to get a digicam pic of it tonight and post it here
Edit: I just can't decide where it should go. Do ya suppose Will would do some interior decorating consultant work?
Will does seem the pansy type so he might be able to help you.
By the way, I haven't seen Will around today. Do you suppose he has new issue? A recent post of his says it could be within the next 48 hours ...
Why not build your own cabinet? Then you get something truly personal and customized to your exact needs, it's cheaper and every time you look at it you can think "Damn, I'm good!"
Cobra -
Cobra ...cobra .....that's usually my sentiment. I know where you're coming from. Standing back and admiring one's own work is about the most rewarding feeling, and going to bed tired, but a "good" tired is great too. But .............Originally Posted by Cobra
I've already built out of wood (myself - no help):
1) An entertainment center (about 7' tall by 5' wide by 2' deep)
2) a game cabinet
3) a room remodel/library at the new house which included closing off a room and building a wall w/bookshelves and an additional 12 bookcases to cover all the wall area
4) tropical fish tank stands (with doors and storage) for a 125-gallon, two 55-gallon and a special 50-gal terrarium
5) Two room additions at the old house (laundry room and a foyer/entrance area w/skylight)
6) A utility shed at the old house
7) A decorative fence at the new house
and non-wood:
1) Dug a 21' wide hole for a pool using only a spade and a wheelbarrow (took 2 months)
2) Covered 900 square feet of the side yard with decorative, red, cobblestone-styled concrete moldings for the pool area as a walking/sunning surface (took 1 year)
3) Dug up and replaced the sod in the entire front yard (took 2 days of solid, hard work)
I don't mean to whine, but my 10" table saw has stress fractures in it from all the use, and my ass is permanently sore
My ego doesn't need any more "affirmations of my woodworking prowess", and besides, I couldn't buy decent lumber for a cabinet like this for $254. And that would be in addition to putting in 16 to 20 hours of fabrication and finishing time afterward ....no thanks. I'm getting that way with my cars too ...life's too short to spend every weekend under a hood, and the money is waaaay less important than the time
Hey! It's not MY fault Greenpeace are coming after you for cutting down the forests!
That's an impressive list - I can see why you want to give your hands a rest!
Cobra -
Greenpeace can kiss my .....never mind
What hands? I've got cracked, bleeding, splintered nubs where they used to be
I'm kidding, but a couple of times I almost slipped and went hands-first into that table saw. That's the scariest power tool there is ...way worse than a chainsaw, IMHO. My sphincter bunches up whenever I turn that thing on ....so much potential pain there ....
A work acquaintance lost concentration once with a table saw and one of his fingers ended up stuck in the ceiling
I wouldn't last five seconds, then!Originally Posted by Capmaster
The scariest tools I have ever used is a router (it's the noise it makes) and an angle grinder. Not very scary compared to what you're decribing, anyway.
'Nuff said!Originally Posted by Capmaster
Cobra -
I've got it! It's because the sound isn't too far from a dentist's drillThe scariest tools I have ever used is a router (it's the noise it makes)
Here is my CD cabinet.
A Craig Tucker original, one of a kind. Made from an old solid teak table top, weighs a ton.
Have not got round to making one for my DVD's, not enough hours in the day. -
That is bloody nice. I want one!
Cobra -
Thanks for the great website. Did you order that product from them?
We have two of these at work and their program for the Mac SUCKS!Originally Posted by beavereater -
I think I found something in your picture Capmaster when I looked a bit closer, see if you can see it also.
Here's the CD Holder I made to hold my VCD's. Holds about 250 and has a swivel base.
Friend of mine has 2 of the small versions of this. Its 1 panel wide instead of 3. They are fine, bit expensive to shop oak but they are nice just the same.Originally Posted by Capmaster
The really nasty titles aren't showing in the pic .....you know, the ones from Holland involving promiscuous ruminants and Tony Blair
Yep. I had originally ordered the fake finish cabinet for $22 less, but then they added the veneer model so I had them change the order at the last minute. They were very friendly and attentive. Good outfit.Thanks for the great website. Did you order that product from them?
Nice work pacHere's the CD Holder I made to hold my VCD's. Holds about 250 and has a swivel base.
Looks like a professional job all the way
In cardboard boxes that almost fill the storage closet on the 2nd floor. I dread it when I need to re-capture one and dig through all that. It's about a 45 minute job just finding a particular title :PWhere you you store the originals -
i'm looking forward to the day i can move out and find somewhere proper for all my stuff, i'm really cramped at the moment.
DVDs
DVD's
DVDs
DVDs
CDs
And of course there's a big stack of cd's in my car too. oh, and a stack on top of my CD player.
*sigh* -
Looks a bit crowdedi'm looking forward to the day i can move out and find somewhere proper for all my stuff, i'm really cramped at the moment.
That it is, as you can see my PC is on the floor, another is under the TV, an unused and an empty case are in the corner behind the dvd rack and there's another unused one in my wardrobe. along with a scary tangle of wires. there's also a scrabble board and a set of star wars LD's in my wardrobe.
It's just prohibitvely expensive to live on my own, and i can't seem to find anyone willing to share, so i shall be lodging here forever. plus i can't be fucked with ironing or cooking and that gets done for me here! (methinks what i really need is a wife.) -
Maybe you do, but be careful ....after being married a while some wives don't attack housework with the same level of enthusiasm they did when you date them and see how tidy their place is. Wow, I'm amazed how PU that statement is, now that I read it backOriginally Posted by flaninacupboard
Let's see greenpeace get in on me!! All recycled solid timber, just aint got round to finishing them yet.
http://community.webshots.com/photo/92702039/92959079lKdHkZ
http://community.webshots.com/photo/92702039/92960904XCpFYQ
At a total cost of around, AU$20 (glue, power, timber and time)
Some would see it as cutting out the middle man's profit,
I see it as doing the forest a favour!!!
BTW, the unit's that were posted, are all very nice.[/img]you say Y,
I say Y not? -
Nice. Now that they're full, maybe print your own labels and put the DVDs in the slim 5.2mm CD cases. Probably fit 600 in the 204-DVD cabinetOriginally Posted by montburnsy
Windows 7 on Socket A nice OC
By ocgw in forum ComputerReplies: 8Last Post: 8th Nov 2009, 07:24 -
Still haven't found a DVD ripper that can...
By tahoma in forum Newbie / General discussionsReplies: 4Last Post: 10th Sep 2008, 08:34 -
Blu-ray to DVD Pro: Nice Program?
By devilcoelhodog in forum Blu-ray RippingReplies: 10Last Post: 10th Aug 2008, 16:21 -
Dealing With DVD Rebuilder: Encoders & Settings to Get Nice Results
By devilcoelhodog in forum Video ConversionReplies: 1Last Post: 30th Jan 2008, 22:55 -
Some Very Nice HV20 Footage
By Soopafresh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 14th Oct 2007, 21:05
