I'm trying to convert 102 dalmations avi to mpeg1
it gets to about 35 mins in to the source then I get a floating point error.
Must be a prob with the avi but can I fix it or is it no good.
seems to play ok in media player
cheerz
Hey man, I have been getting the EXACT same error on HeartBreakers for days now. Just figured it out tonight finally. Turns out there is a corrupt section of the movie. When TMPGEnc stops and gives you that error, write down the time in the movie. Mine was 50:55. So I opened up VirtualDub, found that part of the flick and there was a few seconds of blotchy red crap all over the place. I deleted just those 3 seconds and it worked. I know there is 3 seconds missing from the movie now, but it's the best I could figure out for myself. I still new to this.
Good Luck -
Use "vdub-mp3-freeze.exe" to scan all AVI's for bad frames, it makes a list so you can remove them before convertion.
Hey man, could you be a bit more specific on where that is? I can't find it anywhere in VirtualDub and I don't see it anywhere in the Tools section.
THanks -
dam did what you said and your right film goes apeshit. But it does ot for full 2 mins. So gonna try get another copy, 2 mins to much to cut out : (
THanks
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Hi, sorry its not a regular Vdub, its a modified version called "vdub-mp3-freeze.exe" you should be able to download it from the usual places like grokster, Kazza etc. mail me if you don't find it.
here is the link to the tool:
http://www.datahavenco.com/fairuseguide/software.html
DVD Maestro Entry Point Not Found Error
By criver in forum Authoring (DVD)Replies: 7Last Post: 9th Aug 2011, 11:42 -
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 09:28 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 08:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 02:22 -
Point to point sharing with wifi adapter and wifi router?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Jul 2008, 17:47
