since xbox wont play vcds..is there a way to convert the vcd file to a dvd file and make it so it will play on xbox or ps2....ive tried everything without success..thanks
If your XBOX has an 'upgrade' chip then I would suggest you load XBOX Media Player onto your Hard Drive, it will then play anything a PC can, XVIS, DivX, SVCD, VCD etc from any source, even streamed from the internet!
...but yes, a VCD mpg can easily be authored as DVD using TMPGEnc DVD Author.
/Mats -
i've actually tried this for my ps2.. the ps2 WILL NOT play mpeg1 video.. i had all of the southpark season 7 mpeg1's (vcd spec).
i converted the audio to ac3, built nice little menus in tmpgenc dvd author, popped it in the ps2, it would play the audio when i selected an episode, but no video.. i even tried it with an mpeg2 motion menu as the first play.. even though mpeg1 video is within the dvd sepc the goddamn thing just refuses to.. i'm not sure about the xbox though.
the ps2 will play svcd mpegs w/ patched headers though.
this is one of the reasons i've started doing video captures (for series) at 1/2D resolution..
Video from PC encoded and Burnt to VCD to Play on my DVD R Player
By dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 22:15 -
How do I hook external audio up to my ps2/xbox 360?
By hellfire45 in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2009, 00:37 -
Is there an adapter to use your PS2 guitar on the xbox 360?
By yoda313 in forum Off topicReplies: 0Last Post: 18th Jul 2008, 21:28 -
burnt dvd does not play
By sumeshkri in forum Authoring (DVD)Replies: 12Last Post: 22nd Nov 2007, 02:33 -
dvd burnt using avid wont play on some players
By cheesypuffs in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2007, 10:01
