Damn damn damn...
I`ve got a movie that is in NTSC format 29,97 Fps.
I want to put subs on this. The sub i`ve got ( In sync with the movie and all)
I use VOBedit to demux the movie. Then Ifoedit to multiplex it together with my subs.
Here comes the problem then...
The original movie is 1 hour 34 mins long.
When i have used ifoedit , the movie is just 1 hour and 14 mins long. Ifoedit says that the movie i`ve just made, is in 30 Fps.
Playing it on my pc is no problem. Subs are there and all. But when i put it on my stand-alone, then the display count up to around 5 secs, and stops. The movie now plays without subs. Once in awhile the display number changes, and if i`m lucky there is displayd a sub if the counter sets it self on that sub in seconds.
The movie tends to freeze for a few secs once in awhile.
Does anyone have a solution on this on??? And no! It is not the movie that flauds. I have a couple more that do the same. And they`re all NTSC. My PAL movies is subbed with no probs at all.
Results 1 to 1 of 1
.264 + AC3 Multiplexing problem
By 557953 in forum EditingReplies: 4Last Post: 24th May 2011, 09:16 -
Major synchronizing problem please?
By tendra in forum Video ConversionReplies: 2Last Post: 31st Aug 2010, 11:28 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
Major 'Codec' Problem
By mattstan in forum Newbie / General discussionsReplies: 4Last Post: 25th Aug 2007, 15:18 -
major problem
By Antitrust19 in forum ComputerReplies: 6Last Post: 28th May 2007, 08:30
