i was just wondering is there anything i can use to remove little white lines that appear on clips through out the clip
What 'white lines' do you mean?
Those at the bottom of a frame when capturing from a VCR
or those small ones (like noise) when capturing from TV?
The bottom ones can be cropped/blacked or ignored.
The other one are difficult to remove,but IIRC there is a AViSynth filter for doing that).Maybe have a look here:
http://forum.doom9.org/showthread.php?s=&threadid=57914
Or is it a different problem? -
its lines that run across the screen every so often looks like little crackles
White lines in the VITC area
By youblokle in forum Authoring (DVD)Replies: 8Last Post: 30th Jul 2009, 00:50 -
Tiny white lines on screen during AG-1980 playback
By Bix in forum RestorationReplies: 2Last Post: 24th Apr 2009, 09:20 -
Remove white lines in old video (UmaticSP tape)
By mark23 in forum Capturing and VCRReplies: 14Last Post: 1st Nov 2008, 09:42 -
Betamax - horizontal black lines near white (example within) & other Qs
By PLC401 in forum RestorationReplies: 37Last Post: 25th Feb 2008, 16:09 -
[SOLVED] Removing scrolling lines from videos
By palyons in forum RestorationReplies: 8Last Post: 27th Jan 2008, 22:48
