hello,
I have created a slideshow of all my jpegs (with background music and transitions etc) using Arcsoft Video Impression. The AVI file that it created was huge (1.3gb) for only 15 mins. I then created a SVCD using TMPGEnc (after splitting the audio using Goldwave). This worked no problem and the resulting MPEG was only 316 mb. My DVD player does not play SVCDs so I decided to use the header trick. This is what I did:
1. open TMPGEnc
2. File/Mpeg tools
3. Changed the Type to 'MPEG-1 Video CD'
4. Entered my file name (Slideshow.mpg) in 'Video input'
5. Changed the name to 'Slideshow VCD' in 'Output'
6. Made sure the Type still said 'MPEG-1 Video CD'
7. Hit RUN
The Multiplexing window then appeared and the time bar increased to 100%. At this point the error message "139563 s packets cause buffer underflow. The MPEG file might cause error when played".
The new file that had been created was exactly the same size as the original and (using GSpot) I could see they both had the same properties. Nero would not recognize this as a VCD file !
Am I doing something wrong?
Is Video Impression the best software for this kind of job?
Kind regards
P Williams
Results 1 to 1 of 1
MPEG-2 TS PAT header decoding problem
By jeromedroz in forum ProgrammingReplies: 21Last Post: 27th Jan 2016, 04:02 -
151MB mp4 file - with header problem?
By supermaster in forum RestorationReplies: 7Last Post: 6th Jan 2012, 08:52 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 16:21 -
SVCD / MPEG2 - bad packet stops file.
By Steve Walsh in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jul 2007, 12:03
