Ok I have this problem with an xvid file that has 5-channel audio. I cant save it as Wav in virtual dub(in full processing mode, no compression). Tmpgenc wont accept the video file as audio source so I cant convert the video file with audio.
Error msg in Virtual Dub: "The requested audio compression is not compatible with the input format. Check that the sampling rate and channel count of the input match those of the requested format"
File info:
Decompressor XviD Mpeg-4 Codec
Channels 5(steoreo)
Compression Unknown(tag 2000)
So I cant convert the file to mpeg with audio. Need help
Wow, that was complicated.
Do I have to go through all the steps? Im making an mpeg for SVCD and cdr? -
not necessarily as many steps as the guide. I sill splainify.
1) Load the video into virtualdubmod , not virtualdub.
Extract the audio like the guide sayds.
Encode your voide and video however you like, choose your favorite method, leave the ac3 track alone.
Quthor in your favorite dvd auth package, or use ifoedit to mux into a dv for free. -
Ok, I dont think my dvdplayer can even play xsvcds and I cant burn dvd-r.
So can I just convert the ac3 audio to wav( like they do here https://www.videohelp.com/forum/userguides/160649.php ). And then convert the wave file with the videofile in tmpgenc? Or is that a bad idea? Much worse Quality? -
If you make svcd, the sound quality will be great. Assuming the source ac3 was good (probably is being 5.1)
Go ahead youll be fine.
Is it possible to get 6 channel audio from this file type?
By 54321blastoff in forum AudioReplies: 3Last Post: 13th Apr 2012, 13:07 -
Need help can't convert .mp4 file to xvid using VirtualDub
By s_joy09 in forum Video ConversionReplies: 12Last Post: 19th Jul 2011, 05:52 -
AC3 File: Audio only on left channel
By koberulz in forum AudioReplies: 10Last Post: 25th May 2011, 12:07 -
VirtualDub -- XviD file size problem
By higgins327 in forum Video ConversionReplies: 8Last Post: 29th Mar 2011, 16:05 -
Removing audio channel from dat file
By Lextar in forum Authoring (VCD/SVCD)Replies: 1Last Post: 25th Jul 2010, 22:08
