    Mar 2004
    Long Island NY
    just curious anyone beside me have a problem backing up this movie (the mask (jim carrey))?
  2. Member richdvd's Avatar
    Oct 2003
    Toronto, Canada
    what is the problem?
    Feb 2004
    I am a free man.
    Just a LITTLE more information would probably be helpful here....
    What burner are you using?
    What software are you using?
    What media are you using?
    What is the problem?
    Have you bakced other movies up sucessfully?
    Is it out of sync?
    Does it not fit on a disc?
    Id the sound missing?
    Is there white lines in the picture?
    Is the picture upside down?
    In other words help us to help you......although some will probably claim to be...
    NO ONE ON HERE IS PSYCHIC!!!!
    Zworg2
