I have been working a little with XML (on webpages) and I was very confused when I saw the XML word around here on this site... then I looked into it a little and I guess you can make more complicated burning using XML but what exactly can you do? Donīt need a lesson in XML just an explanantion what I can do with it! for example... what's an entrypoint... what benefits do I get form authoring XML on my VCD?
Thanx/
Lars -
You don't actually burn the XML on your VCD.
With VCDImager, you can create the menus and interactive structure of your VCDs. This is done by editing an XML file which describes how the interactive content of your VCD is put together.
"Entrypoints" are used to describe starting points on a VCD tracks other than the beginning of the track. This allows for a form of "chaptering" on a VCD.
Regards.
Michael Tam
w: Morsels of Evidence -
that sounds interesting would there be an example of how it is done if there is an example of it out there lemme know
Go to the official VCDImager website. There you can download the latest build of the proggy, get the manual, as well as download sample XML files from the XML "repository".
There is also a PAL/NTSC demo VCD which displays what can be done with VCDImager and the VCD2.0 format, as well as a few other useful things (e.g., like screen tests).
Regards.
Michael Tam
CLI to XML
By eon_designs in forum Video ConversionReplies: 1Last Post: 29th Apr 2010, 11:50 -
Megui xml error
By headhunter03 in forum Off topicReplies: 0Last Post: 4th Apr 2009, 10:19 -
srt to xml ? any tools ?
By sat-jokar in forum SubtitleReplies: 3Last Post: 10th Mar 2009, 09:12 -
Transport stream for XML?
By TrupsT in forum Video Streaming DownloadingReplies: 1Last Post: 30th Jan 2009, 12:25 -
DriveImage XML
By blockie@sbcglobal.ne in forum ComputerReplies: 2Last Post: 25th Jul 2008, 17:25
