hello ppl
ive tried many times to encode my divx of 'red planet' to vcd format using TMPGenc (latest version) without success. I get a blue screen error (Windows ME) exactly 9 minutes and 9 seconds into the film everytime. Ive tried using earlier versions of tmpgenc and i get the same error at the same point in the film. Is there an error in the divx at this point (there doesn't seem to be an error when playing the divx)? Ive tried using different templates and aspect ratio's
PLease help me out?
thanks
thanks
will someone actually reply to the thread instead of just looking at it....0 posts, 65 views. wtf????
Your problem is not TMPGEnc, but rather windows ME. SCRAP IT NOW! its worse than windows 3.1
vudu, nobody is OBLIGATED to help you. Do you think that you DERSERVE it or something? If somebody knows something that could help and is willing to post, you should be grateful.
You should try helping yourself first. For example, click on "search" at the top of the page. Also, try to describe your problem more precisely and the exact method you took.
Regards.
_________________
Michael Tam
<font size=-1>[ This Message was edited by: vitualis on 2001-11-05 02:20:21 ]</font>
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 23:22 -
TMPGEnc Author Keeps Re-encoding
By lostinspace00 in forum Authoring (DVD)Replies: 13Last Post: 8th Apr 2011, 09:16 -
Encoding using TMPGenc 4.0 Xpress
By abdul_sma in forum Video ConversionReplies: 1Last Post: 19th Jun 2010, 08:15 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 23:23
