My first disc on the Simpsons Season 3 set has a huge scratch on it, so I figured I'd make a backup. I used Decryptor to rip it, then DVD2One to shrink it, and the files play fine off the PC's hard drive, but when I burned it to DVD-R, the problems arouse!! In every one of my DVD players, the menus play just fine, but when you try to play an episode, a message comes up that states that it is the wrong region disc. What gives? Has anyone encountered this before? I have backed up a ton of DVDs with the above method, as well as with DVD Shrink. and have never seen this error.
Take a look at this thread: https://www.videohelp.com/forum/viewtopic.php?t=176015
I had the same problem last night, but haven't had time to try the "fix" yet. -
Thanks a lot, bud!! It's been so long, I almost forgot I posted!!
Help...Blank DVD-R disc shows region 8...
By Praetorian_Prefect in forum Newbie / General discussionsReplies: 9Last Post: 23rd Jun 2011, 23:17 -
DVD+R won't play, have I bought the wrong format? - New post/problem 15/12
By yultie in forum MediaReplies: 20Last Post: 17th Dec 2010, 13:59 -
Blu-ray backup won't play in PS3
By DGenerateKane in forum Blu-ray RippingReplies: 40Last Post: 27th May 2010, 00:57 -
Have a region 0 DVD, but my HP DVDPlay won't play my R1 DVDs
By scc1983 in forum Software PlayingReplies: 2Last Post: 24th May 2010, 05:19 -
Newbie, advise for easy 1 step backup of dvds
By mbogda in forum Newbie / General discussionsReplies: 5Last Post: 4th Sep 2008, 13:18
