Hi
Ive just converted a film i had made, used TMPGEnc, then converted audio seperartly with VirtualDUB and FFMPEGUI, and Authored it with TMPGEnc DVD Author..
But when playing back on my DVD player, the video seems to twitch every 2 seconds or so, the audi is fine and it all stays in Sync..
Any suggestions anyone?
I suggest that you get used to twitchy video!
Either that, or give us more info on your video.
Is it from FILM? OR, is it interlaced?
Is it from DV?
What is the encoded framefrate?
What is the play framerate?
Did you apply a 2:3 pulldown?
Are you sure that you got the field order correct?ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Is it from FILM? OR, is it interlaced? - I think its interlacedIs it from DV? - Nope..
What is the encoded framefrate? - CBR 6500
What is the play framerate? - How do i tell this?
Did you apply a 2:3 pulldown? - ???Are you sure that you got the field order correct? ---???
As you can tell im kind of new to all this so all help will be gratefully recieved..
Jumpy video from Nikon d300s
By Owen1 in forum Newbie / General discussionsReplies: 19Last Post: 2nd Jun 2011, 04:27 -
NEWBIE - Video jumpy after converting
By jaco33 in forum Newbie / General discussionsReplies: 0Last Post: 6th May 2010, 11:00 -
Jumpy video with animated films - like there are frames missing!
By junks in forum Authoring (DVD)Replies: 8Last Post: 10th Jan 2009, 10:27 -
Jumpy Video with DVD Flick
By matthewjohn23 in forum Newbie / General discussionsReplies: 2Last Post: 16th Jul 2008, 22:24 -
hd video files are jumpy / jerky
By adamvfb in forum Newbie / General discussionsReplies: 3Last Post: 2nd Oct 2007, 13:12
