It appears there are compatability issues on the horizon for older 1x and 2x DVD-RW burners with new 4X disks.
http://www.dvdwriters.co.uk/
Early adopters of the format get shafted yet again !
By the way, I didn't intend to start yet another format flame.
I just felt I should point this problem out to people with older burners.
I use a dual format burner and am quite happy with both "+" and "-" disks and have no preference over either. In fact I mainly use 4x DVD-R disks as they're currently cheaper.
Oooooooold news..........
https://www.videohelp.com/forum/viewtopic.php?t=212260 -
Ah !
Not been reading the posts here for a while.
Still, it won't do any harm to raise the issue again in case some people missed it first time round.
I'm surprised their hasn't been more response to this subject though. -
Well, when you get right down to it, CD-RW's have the same problem. The "high-speed" media designed to work in 4X-10X drives won't work in the older "low-speed" drives that max out at 4X, which is why they still make the two different types. I've also heard reports that modern 40X-and-above CD-R media can be problematic in older <10X -R drives.
So as fodder for the plus-vs.-dash wars, it's not all that great of an issue, since we've been dealing with this kind of problem for a long time in the CD-R world now.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
VirtualDub Error 'Says "Couldnt locate decompressor for format xvid"
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2010, 23:05 -
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 20:50 -
Seeking "One-Type-Fits-All" format to display on iPod, PSP and Bl
By GrayStrickland in forum Portable VideoReplies: 0Last Post: 25th Mar 2008, 09:12
