  1. hi all,
    I want to make a copy of a move that was backed up using dvd x copy. I believe that dvd x copy has some copy procection on it preventing re-copying. Is there any way round this? Ive got DVD Shrink and would prefer to use this if possible.
    Thanks a lot.
  2. You should not want to copy a backup of a movie made by DVDXCOPY. That was 321 Studio's get out of jail way of thinking they were OK but look where it got them.
    I am told on good authority that Nero will copy the backup
  3. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    Roxio Disc Copier can do the same, but that wouldn't be ethical and I can't condone it.
    Nothing can stop me now, 'cause I don't care anymore.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Copy all of the files to your Hard Drive. These files have already had encryption removed and have been shrunk to fit on 1 DVDR. Burn with Nero.
    If in doubt, Google it.
    Mar 2004
    soddy-daisy
    dvdxcopy is designed to prevent copying backups. there is a freeware program to defeat it. jimmalenko method defeats this and will work also.
    dvdxcopy= fast & easy
    dvd decrypter/dvd shrink= slower, cheaper, better quality
  6. That is odd, I just backed up 3 of my movies with NTI that were backed up with DVD X Copy, worked for me.
    Mar 2004
    soddy-daisy
    Wingpal Posted: Mar 25, 2004 17:10
    you may be on to something others have been looking for. xcopy claims this can't be done, link
    http://www.321studios.com/press/2.11.2003.htm
    note third paragraph.
  8. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    That should probably read "...backup of a backup..." As far as I know, you could always copy a backup, just can't backup a backup with DVD X Copy.
