  1. Member bballnut's Avatar
    Mar 2003
    I have been using DVD Workshop to burn my home movies to DVD up to 3 months ago. I have not used it in the last 3 months because I have been concentrating on DVD backup to DVDR. I finally had success with DVDShrink, Autoshrink, and Nero to backup my DVD's but now I am starting back with my home video to DVDR using the same method as before. The only thing that has changed on my system is the above installed programs. Now DVD Workshop freezes up at the final step of burning the DVDR. It works fine setting up the DVD (menu, etc.) but just freezes on that final step. Is there a conflict with any of these programs with DVD Workshop? I am using Workshop 1 not 2. I have uninstalled workshop 2 times and reinstalled but the same thing keeps happening.
    thanks in advance.
    Duke Rulez
    Go Blue Devils
  2. Have you tried downloading and installing the update patch for version 1.3 of Ulead DVD Workshop?
    The update patch can be downloaded from the Web page at the following link:
    http://www.ulead.com/tech/dws/dws_ftp_dws1.htm
    Hope this helps,
    Jerry Jones
    http://www.jonesgroup.net
  3. Member bballnut's Avatar
    Mar 2003
    I went to this link but the 3 download sites will not open. It tells me this page is not available for each of the 3 sites to download the patch. what am i doing wrong?
    thanks for your reply.
  4. You're not doing anything wrong.
    The Ulead Web site servers have apparently been having some problems during the last couple of days.
    I just tried and I was able to download the update patch.
    Try again.
    Jerry Jones
  5. Member bballnut's Avatar
    Mar 2003
    I just tried again with no success but I will give another try later.
    thanks for you response.
