Page 3 of 3
FirstFirst 1 2 3
Results 61 to 74 of 74
  1. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I'll wait until Pioneer releases its DL model that can do -. Until then, I'll continue using my 106.
    I don't have time for + at all
    If in doubt, Google it.
    did everyone miss my .
  3. Member kabanero's Avatar
    Feb 2001
    HockeyTown
    You don't know what you are missing
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I have only ever used - because it works on all my devices.
    Given that I have never used +, I find it extremely hard to believe that it is "better" than -. If it is, would you care to provide me with an example and a resoning as to why ?
    As far as I am concerned, it all comes down to compatibility. I have extremely good compatibility with -, so why try anything else ? In the end, it is what works for me that is important to me. Good luck to you though.
  5. I use both formats
    1. I haven't find a single player that wouldn't play my + discs burned in my good old external Ricoh5125 (more than 50 players, borthers, parents neighbors,etc...)
    2. I have a Pioneer DVR106 that can write any DVD-R I have tried so far, even the ones that fail to burn in my friend's LG4040 and NEC1300
    3. I have used Nero AND RecordNow with very very few problems
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
  6. I use DVD-R and DVD+RW and I'm happy with both.
    I'm even starting to warm-up to 2x DVD-RW media. Memorex media. And I've been using it with Nero lately. Whoda thunk?
  7. Originally Posted by indolikaa
    What do I think?
    You must be the luckiest Optorite owner on Earth. :P
  8. Member kabanero's Avatar
    Feb 2001
    HockeyTown
    So, you are giving up 4x DVD+RWs to 2x DVD-RWs?
    You should be proud of yourself.
  9. His Optorite203 can't write rewritable medias faster than 2.4x
  10. Not one to get too involved in the +/- war but +RW beats the pants off -RW its actually useable.
  11. I've only burned - discs so I can't really say for sure if one format is better than the other. But from what I understand PS2 will only read backups that are written in the - format. Take it for what its worth but I see that as an advantage.
  12. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    and -RW isn't usable ?
    I don't understand.
  13. The Sony Dual layer is available on preorder from Buy.com For $203 but there is a $10 off coupon at pricegrabber, so $193. I don't think Sony makes it.
  14. I though Sony started to rebadge Liteon?
