hi I just join yesterday, I have a question that nobody can seems to answer,
first of all, I dont have neither a dvd or a dvd player.
I hava a VCD movie that I wanted to extract/rip into my pc in avi format form since I notice .avi more smaller in size than mpg(correct me if im wrong).
someone told to copy n paste .dat and use vcdgear to convert it to mpeg BUT it turns out 600+MB!, is there a way to convert it to avi in compress form???
does the how to extract dvd, can be applied to VCD???
600 MB sounds about right.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
You will find that VCD is about as compact as a lower resolution video file can get. AVI (As in DIVX, may be able to get it smaller, but only with a lot of work. I would just keep what you have. As VCDHunter said, 600+ is normal. You might study the VCD format under 'What is' to the left. If you really want to convert, you have some reading to do. If you only want to store it on your computer for viewing, maybe DIVX is what you need.
In general you're right, Divx (a type of compression used in many avi's) can compress better than a similar mpeg. Once you have extracted your mpeg you can convert it to avi using several programs. Look up mpeg to avi under format conversion in the guides section, over there <-<-<-.Originally Posted by paseo"Art is making something out of nothing and selling it." - Frank Zappa
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Question : Why i can't copy from Protect VCD
By indianguy077 in forum Authoring (VCD/SVCD)Replies: 23Last Post: 24th Mar 2009, 07:42 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43 -
VCD MPG1 file to CD Question
By Excelsior123 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 22nd May 2008, 20:14 -
Newbie question about VCD files for CD-ROM
By donn in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 18:37
