I wanted to create a gradient effect on one of my pictures in which the image changes modes ie black and white to color. It would start with a color photo and slowly lose color until it was black and white. Is there any way that I can do this in Photoshop? Do I need a plugin? Any help please....
Thanks in advance.
There are probably many ways to do that, but this is what I would try:
Duplictate the layer so you have 2 layers of color image, or you can do 3 layers for more detail if you like.
Select the bottum layer, go into Hue and Saturation adjustment and reduce Saturation to 0. This will make that layer Black and White.
Select the top (color layer), use the eraser with the largest softest brush, and start erasing away the Color layer to reveal the Black and White layer beneath it.
You can also use a third or fourth layers in between for more control. You can play with the opacity.
Just experiment, you'll be amazed.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Can't you apply a gradiant to the transparency between two levels, one being B&W and the other color.
Big Government is Big Business.. just without a product and at twice the price... after all if the opposite of pro is con then wouldn’t the opposite of progress be congress? -
I just did a picture like you're trying to do. This is the simplest and quickest method:
1) Select the Gradient tool, change Mode from "Normal" to "Saturate".
2) Select the Gradient patern you want and drag the tool across the image.
That's it!Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Yes, this is what I would do if you wanted a uniform gradient. Using the eraser method is best left if you want an "unclean" or "hand-painted" look to the gradient.Originally Posted by BobV
I agree. Select gradient tool, set to saturate. You may need to click the gradient palete in the upper left and adjust your colors, to foreground to transparent and your black slider up to where you want it. but it's by far the easiest.
Thanks it worked great. Just need to add several gradients to truely achieve a noticable difference. Damn if only I knew about dvdrhelp.com 3 years ago, my high school year book would have rocked.
New Adobe Photoshop image deblurring algorithm
By poisondeathray in forum Latest Video NewsReplies: 3Last Post: 13th Oct 2011, 23:12 -
Adobe Premiere Pro: I used DV footage and Photoshop stills - how to export?
By neckneck in forum EditingReplies: 12Last Post: 20th Dec 2009, 15:29 -
Picture as Menu Background in Adobe Photoshop
By boofer in forum Authoring (DVD)Replies: 3Last Post: 16th Oct 2008, 01:41 -
Adobe Photoshop Elements 6
By Mållgan in forum Capturing and VCRReplies: 0Last Post: 2nd Aug 2008, 04:15 -
Problems with Adobe Photoshop Trial Download
By kerrex_2006 in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2007, 11:19
