I have a Studio DC10+ card in my computer which does a great job capturing from my Sony camcorder, no complaints there. But when I connect my VCR (Sharp) to the DC10+ to capture from a normal VHS tape, I can see the video in the preview screen, but it does not capture a single frame. I tried different software (Studio DC10Plus, vidcap, VirtualDub) but same result. No frames captured, no frames lost, no frames at all! I connect the VCR using a SCART adapter to the composite video input of the DC10+ card. Help! What do I do wrong?
i got one the other day it it was workin ok, maybe its something to do with your VCR....
peace -
forgot to ask man, can you tell me wat settings you use in studio DC plus software? ie frame rate, size etc... do u make VCD's? Does it come out well? Do you get motion streaks? hahaha 20 questions.. sorry man,
thanks
I got it working, changed something in the BIOS settings and that was it. Still don't understand why it worked from camcorder but not from VCR, anyway...
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 04:03 -
capture from vcr
By bbxrider in forum Capturing and VCRReplies: 27Last Post: 16th Aug 2009, 17:18 -
Miro DC10 /DC10+ and fedora
By bmw524 in forum LinuxReplies: 2Last Post: 14th Nov 2008, 15:54 -
DC10 Plus Capture
By jackylhome in forum Capturing and VCRReplies: 1Last Post: 30th May 2007, 18:12 -
Studio DC10 Plus analog Card, XP and Studio 10 capture split in half
By jackylhome in forum Capturing and VCRReplies: 0Last Post: 22nd May 2007, 23:48
